depends on how the box feels .
I use mt90 on most applications and heavy duty shockproof for those that crunch gears .
You'll need around 2.5l
Hey chaps,
I've tried searching Google, these forums and Vortex but I still can't fine a definite answer to this: what Redline fluid do I need for my MKIV GTI manual transmission? I've seen MTL, MT90, lightweight, shockproof etc but I don't know what to choose/look for specifically. Will I need MORE than two litres to fill the gearbox?
I am also considering Royal Purple fluid - has anyone used it? If so what specs should I look for?
I am hanging out to change the fluid and get back my slick gear changes!
Thank you
2000 Mk IV GTI
Thanks for your help mate! It crunches rarely when engaging reverse. I will opt for the MT90.
Much appreciated. Cheers Bug racer
2000 Mk IV GTI
Royal purple make quality fuels just make sure you match the thickness of your oil. Reverse crunch could be a sign of synco wear. But your spot on by doing a gearbox oil change first.
Syncro on reverse, I think only T3 syncro's had that.
Widebody Cayman S Turbo, 83 ur Quattro
2000 996 C4 cab,12 Scirocco R OEM+ STG2+
72 914 (3.2S boxster pwr), 92 G60 Corrado
76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
Definitely MT90
no syncro on reverse, it's a straight cut gear.
I still haven't gotten around to doing this
2000 Mk IV GTI
Ha ha dubbed, you sound like me putting my new springs in!!I still haven't gotten around to doing this
at risk of sounding noob, if gear changes feel fine is there a need to change mtf at all? even after xxx kms and xxx years?
