Results 1 to 10 of 16
Thread: MKIV Manual Transmission Fluid
    Apr 2008
    Question MKIV Manual Transmission Fluid
    Hey chaps,
    I've tried searching Google, these forums and Vortex but I still can't fine a definite answer to this: what Redline fluid do I need for my MKIV GTI manual transmission? I've seen MTL, MT90, lightweight, shockproof etc but I don't know what to choose/look for specifically. Will I need MORE than two litres to fill the gearbox?
    I am also considering Royal Purple fluid - has anyone used it? If so what specs should I look for?
    I am hanging out to change the fluid and get back my slick gear changes!
    Thank you
    2000 Mk IV GTI
    Apr 2006
    VW Race HQ - Sydney
    depends on how the box feels .
    I use mt90 on most applications and heavy duty shockproof for those that crunch gears .
    You'll need around 2.5l
    Apr 2008
    Thanks for your help mate! It crunches rarely when engaging reverse. I will opt for the MT90.
    Much appreciated. Cheers Bug racer
    2000 Mk IV GTI
    Royal purple make quality fuels just make sure you match the thickness of your oil. Reverse crunch could be a sign of synco wear. But your spot on by doing a gearbox oil change first.
    Jul 2005
    syncro
    Syncro on reverse, I think only T3 syncro's had that.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Sep 2007
    Definitely MT90
    no syncro on reverse, it's a straight cut gear.
    Apr 2008
    I still haven't gotten around to doing this
    2000 Mk IV GTI
    Jun 2008
    Ringwood, Victoria
    Ha ha dubbed, you sound like me putting my new springs in!!
    Mar 2009
    sydney
    at risk of sounding noob, if gear changes feel fine is there a need to change mtf at all? even after xxx kms and xxx years?
    Apr 2008
    Quote Originally Posted by hienous View Post
    Gearbox oil should be treated as a normal service item, albeit at longer intervals. I'd probably suggest every two years or every 50,000kms.
    2000 Mk IV GTI
