Results 1 to 10 of 17
Thread: MK6 GTI Brake Fluid
    Mar 2010
    MK6 GTI Brake Fluid
    Guys, the time has come for the brake fluid to be replaced.
    Any ideas on a good fluid to use?
    Or stick with the OEM stuff?
    MK VI GTI / 5 DOOR / DSG / LEATHER / TORNADO RED / APR STAGE 1 / CARBONIO CAI STAGE 1 + 2 / VMR VB3 18" MATTE BLACK
    Jan 2009
    Quote Originally Posted by Sir_GTI View Post
    Most VAG models from 2006 onwards use a low viscosity brake fluid, in order for the electronic stability control systems to work optimally at low temperatures.
    As such, the workshop manual says the brake fluid must conform to VW TL 776 Z and hence meet VW 501.14
    You don't have to use the genuine fluid, but as we are not in Europe, alternatives are few and far between on the local market.
    Adelaide hills, SA
    Jan 2009
    Yep, ATE SL.6 is fine. Other options include Pentosin DOT 4 LV, Textar DOT 4 PRO, TRW DOT 4 ESP, etc.
    Basically, any brake fluid that meets ISO 4925 Class 6 should be fine.
    Mar 2010
    Thanks all for the replies.
    Great info. I like the ATE SL.6.
    Does anyone know where I can get the ATE SL.6 in Sydney?
    I could not see a listing on the site of local vendors.
    Jun 2009
    ATE or redline are meant to be better than OEM
    Also Valvoline synpower fluid but i don't know if we have that in Aus.
    Sep 2010
    Any one tried Endless brake fluid on their Mk6 GTI??
    2011 Golf GTI | APR Stage 2 | APR Downpipe | Milltek Catback | Oettinger Intake | Weitec TX Plus Coilovers | OSIR Carbon grille & spoiler | Pivot 3in1 Boost gauge | Custom Twin Intercooler + Turbo Discharge pipe | Whiteline Bump steer correction + Swaybar endlinks | SPEC Stage3+ Clutch kit | Nitto NT05 | Superpro 24mm F & R Sway bars + Control Arms & AntiLift Kit + Roll Centre Adjustor | VMR VB3 | AP Racing CP5200 BBK |
    Dec 2012
    Does anyone know where to buy a vw501.14 compliant fluid? Id prefer ATE but can't find it anywhere.
    Dec 2008
    Sydney/Canberra
    HSY will sell you ATE, and you should be able to get the Textar fluid from Imparts.
    Be prepared to BS them about being a trade customer
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by richmurphy View Post
    any DOT 4 fluid will do, but given that you have a nice BBK, I would at least use Penrite Racing RBF600 or Motul RBF600 fluid and change it every 6 months.
