Originally Posted by
DeepBlue
I was looking at using a suitable vacuum pump, either hand-operated or electric to suck out the old oil via the dipstick (as the dealer mechanics do) rather than go via the traditional sump drain plug route.
I 100% agree with Umai Naa. On my last oil change on the Golf, I noticed the outer LHS driveshaft boot was starting to split. I wouldn't have known unless I was under there & instead of needing just a boot could have resulted in an expensive CV joint.
I think the only reason dealers suck out the oil is just a time thing, not because it's better.
I have used a plug twice without any leaks using a torque wrench but realise the seal may not work as well being used twice.
Numerous Mk1 Golf diesels
