View Poll Results: Does VGA need to fast track Bio Diesel/Ethanol Capability ?
Voters
27. You may not vote on this poll
  • Yes VW Group OZ should bring Bio Diesel & Ethanol Capability
    23 85.19%
  • Only BioDiesel Capability
    2 7.41%
  • Only Ethanol Capability
    0 0%
  • No to Both Ideas
    2 7.41%
Results 1 to 5 of 5
Thread: Does Volkswagen Group Australia need to fast track Bio Diesel/Ethanol Compatibility ?
    Jan 2007
    South Australia
    Question Does Volkswagen Group Australia need to fast track Bio Diesel/Ethanol Compatibility ?
    Does Volkswagen Group Australia need to fast track Bio Diesel Compatibility ?
    I see some threads where users use Bio Diesel should VGA be at the forfront of Bio Diesel technology and Ethanol technology in Australia ?
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    brackie Guest
    07 diesel models
    I believe that the new common rail diesels that VW are bringing out can use biodiesel.
    Jan 2007
    South Australia
    hmmm I've read ones with DPFs cannot use Bio
    - Ben
    2008 Jetta 2.0L FSI
    Sep 2006
    My 2005 R5 TDI Touareg (a typical PD engine without DPF) can run on biodiesel - there is a whole chapter on use of FAME (fatty acid methyl ester) fuel in the owners manual. The only consequences are (according to the manual) slightly lower power and slightly increased fuel consumption. Also the need to change the fuel filter more often. VW Aus does not approve the use of biodiesel as they like a well covered a$$e - they are not yet happy that it would be made to an appropriate standard. This is despite the A.S. for biodiesel now having been in place for a couple of years. They need to confirm the research that says there is no harm in using it with a DPF, as that affects newer vehicles; but I believe that to be mostly an issue of not wanting to make a decision as well.
    IMHO they would get a lot of kudos if they went full-throttle into pushing the "flex-fuel" nature of every diesel they have ever made.
    ..Neil
    Audi Q5 2.0 TDI
    sold and missed: '05 Touareg R5TDI
    SWMBO: '08 Golf Pacific TDI DSG
    T5 Multivan 2.5TDI
    Moonan do you know if the Multivan engine is the same as the Touareg engine, and do you know if it is fine with Biodiesel? I put bio in it a couple of times without realising it and didn't notice any difference, then when I noticed the sign on the bowser I rang VW and they said no.
    thanks
