Has no one ever used anything?
Guys i have read a few threads on tdiclub and it is common for those guys to use additives in the fuel for different reasons. Most would appear to be for better economy, but there is also some there using them for power.
Has anyone used anything here?
Please post up what brand and what results you got.
Cheers,
Jamie
Cheers,
Jamie
Cheers,
Jamie
I was looking at some yesterday at the servo too mate, what with the dyno upcoming and all
Seems to just clean out dirty motors, thus restoring power to standard.
I don't think we have a K104 additive option!
Been reading the tdiclub as well.
Have plenty of threads regarding improving fuel efficiency and additives.
Have not come across any additives over here like they have, but still searching.
The best improvement still seems to be... to take the foot off accelerator.
Dam shame, might have to give her a squirt of propane
Cheers,
Jamie
Yes I too have been looking these additives and have come accross the following;
BiTron
http://www.users.bigpond.net.au/kcsf...hnology.htm#DC
Flashlube
http://www.flashlube.com.au/en/diese...ner/index.html
Also considering....
http://www.morison.com.au/
My problem is, OK I would def use the Morison fuel filter but do I also use both the Bitron and the Flashlube ?????
Try Moreys "Diesel fuel smoke killer".
http://www.moreyoil.co.nz/details.ph...11&productID=2
AMSOIL Cetane Booster
http://www.amsoil.com/storefront/acb.aspx
You can get these in AU.
Cheers.
Thanks guys, that's awesome. How cheap is that Flashlube $3.25 per tank and claims economy gains up to 6.5%. 6.5% in our late models diesels is hard to believe but at that price any gain is dam cheap.
I suppose you would have to weigh it up, would you get further on $3 worth of fuel?
I really wonder if there is any performance gains might be worth a shot though at that price
Cheers,
Jamie
Of those I understand only Amsoil and Morey's make cetane improvment claims. Performance benefits from them all arise presumably because of injector cleaning capacity. Cetane improvement should reduce engine noise.
Morey's contains a biocide, which sounds like a good idea to use periodically at least.
Given that VW brochures specify 51CN diesel for newer engines and tha standard diesel does not always meet 51CN (since it is made to minimum 46CN per the diesel fuel standard), perhaps more people should be routinely using cetane improvers.
Perhaps someone running an engine where 51CN is recommended should ask VW for an official response.
2015 Polo Comfortline 6M + Driving Comfort Package
2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
(2008 MY09 Polo 9N3 TDI retired hurt hail damage)
Gday.
Diesel fuel additives like Chemtec diesel power or the diesel doctor are great for killing algae and dispersing water in the fuel and it also acts as an upper cylinder lubricant when used in low sulphur fuel. I have used them in my truck and my Nissan patrol and I never had an issue with blocked filters or water in the fuel. Cheers.
