Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Diesel fuel additives
  1. #21
    Adelaide hills, SA
    The Speed Tec Diesel seems to improve diesel economy and cut back visible smoke. I refueled today with BP Ultimate from a bit over a 1/2 tank - 9.35L/100km.
  2. #22
    Jan 2008
    Sunshine Coast
    Blah, blah, blah, what about the POWER???
  3. #23
    Adelaide hills, SA
    Quote Originally Posted by cogdoc View Post
    Better than the ECU re-flash.
    It feels a little bit quicker of the marks I would say. Also can drive in 6th gear at the lower speed and feels more torque in 5th gear.
    It needs to be taken to racetrack as the instruction on the bottle suggests. I have no time for that.
  4. #24
    Apr 2009
    Just a word of caution guys,
    Your diesel is the only thing that lubricates your fuel injection system. If I were you I'd be checking the lubricity (oiliness) of any product I put in my tank. Rub some on your fingers. If it is like petrol or thinners then you may be prematurely wearing out your fuel pump / injectors as it will offer very little in the way of lubrication.
    Personally, I think there is no substitute for 100% good quality diesel. The only time I'd be putting anything else in my tank would be if I had algae in there.
    Just my 2 cents worth.
  5. #25
    Apr 2009
    Quote Originally Posted by bluey View Post
    Curious to know how you go. I have been watching smoke out the back in headlights behind at night using BP Ultimate.
    Any diesel smoke will show up 10 times worse when you look in the mirror at night and have someone else's headlights shining at you. What does it look like in the daytime? That's the true test.
  6. #26
    Adelaide hills, SA
    Quote Originally Posted by Ozram View Post
    That would be too late mate.
