Results 1 to 1 of 1
Thread: Information about the fluids & lubricants in all vw models
    Adelaide hills, SA
    http://www.vwwatercooled.org.au/f112...nes-47140.html
    Approved lubricants for all kind of applications on VAG cars
    COOLANT – topping up.
    Use only VAG G12 plus and VAG G12 plus plus coolant concentrate mixed with distilled or deminerialized water in ratio no less than 40% concentrate 60% water, 50:50 ratio is preferred. Any contamination of the coolant with other brand of coolant will result in a chemical reaction and corrosion of the cooling system.
    Perfect for lubricating hinges, sliding doors and the slides on the sunroofs
    Intake system cleaning http://www.vwwatercooled.org.au/foru...-ks-43296.html
