Originally Posted by
Youdotinmymirror
Just checked the engine oil level in the morning when cold and it seems to have gone up about 1-2mm than when it was warm yesterday. It is different to what I've read so I guess filling it when cold would be better although shouldn't make a big difference if it's at low and filling it minimally.
Cant see how there would be less showing cold than hot.
When the engine is running the oil is circulating through the block therefore a certain amount is not in the sump so level will be lower. When you park the car and let it cool down the oil in the galleries runs back down due to gravity and when it all gets to the bottom the level will rise. I always check my oil in the garage before I start it in the morning when its cold. Pull the stick wipe it and put it back in and then take that level. Never fails. Whatever method you choose always do it the same way. Anyone who waits for the warning light to come on deserves all of the consequences they may get. Oil needs to be checked at least weekly if car running every day.
When travelling full time I checked water, oil and tyres EVERY MORNING. Same when I drove buses Forget and you would be hauled into the office to explain why.
