Results 1 to 10 of 12
Thread: changing engine oil and gearbox oil.
    Nov 2007
    brisbane
    hey people
    just wondering how much oil the VR6 will take with the filter change and also where the automatic gearbox filter and dain plug is and what gearbox oil to use?
    thanks
    rhys
    Point Cook, Vic
    crank case i think takes about 6L from memory.
    Gearbox takes 2L I think?
    have a look at any of the major oil brands and they will tell you capacities and which oil to use. The castrol site has a pretty good searchy thingo
    Nov 2007
    brisbane
    on the castrol site it says 5.5L oil including filter and 3L for the auto trasnmission now where is the drain plug for the trans fluid?
    cheers
    rhys
    Camden, Sydney
    Some of the VR6 Autos dont have a drain plug to empty em, you need to remove the pan.
    There is a special way of refilling them, involving needing to know how hot the fluid is.
    I`d take it to a VW place or Auto specialist for that job..
    May 2007
    Moorooka, Qld
    passatworld have a few threads on changing fluid in a ZR auto.
    Basically, drop the pan. There's also a filter/screen thingo in it that gets changed as well.
    The theory didn't seem too challenging. The process for measuring oil level was based around the car being at operating temp (80 degC?) - wherever the needle normally sits.
    Jan 2007
    Is changing the oil on the VR6 the same as the GL and CL models?
    Apr 2006
    Nth of Nowra.
    Wink Auto
    1, Drain out what you can with the filler plug the rest by removing the pan (cold/warm).
    2, Replace the filter & pan rubber seal.
    3, If no dip stick for trans, remove the red coloured plastic cap off the filler tube above the front pan area of the trans.
    4, With a small screwdriver prise out the two plastic tangs this will allow the releasement of the black filler plug.
    5, Lift the plug up & out of the filler tube. Be careful as the tubes sometimes come out with the plug because of age, the tube tangs just snap off.
    (I would replace tube & O ring anyway).
    6, Fill up with 3+ liters of VW ATF.
    7, Now with VAG-Com etc, the Trans fluid temp needs to be checked.
    8, Start the engine & allow it idle. Keep an eye on the trans temp once @ 35 Deg's remove the drain plug & allow the fluid to drain out until it starts to drip. Once done refit the plug. Note: If no fluid comes out, you need to add more.If temp goes over 45/50 Deg's fit plug turn off. Once cooled try again.
    06 Jetta/09 Pirelli/DSG
    08 T5 BPC/Auto
    08 Caddy Maxi life TDI/DSG
    12 Up!.
    Camden, Sydney
    This is the correct way. You need a thermostat or vag com to check the oil temp of the transmission or it will not work.
    Try it at home with insufficient tools at your peril.
    Matt
    Feb 2008
    Adelaide,Oz
    VR6boy,just done mine, auto gearbox on a T5.
    http://www.brick-yard.co.uk/forum/fo...TID=23701&PN=1
    Steve
    04 T5
    May 2006
    Adelaide South Australia
    Matt
    I don't believe the level is as critical as VW says. When I drained my T4 it had been over filled by at least 1/2 litre,maybe more[can't remember] & it worked perfectly. I have read on an American site where this guy had some model VW auto from new & he found it had been over filled from new. Maybe the level can be slightly higher but not lower, I don't know. That said I would try & fill as best you can to the correct level. When I changed mine, I ran it & guessed the Temp by feel. On the T4 the temp is 35 - 45 degrees C. This is very close to blood temp eg compare the pan temp with your forehead. I have also read that most VW workshops in the USA don't use VAG COM to check the temp when setting the oil level.
