Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Castrol Edge Sport
    Adelaide hills, SA
    Quote Originally Posted by Catfish View Post
    This is all good info.
    I've deduced from the Mobil site that (confusingly) there is a Mobil 1 5W-30 that doesn't appear to meet 504/507 and a Mobil 1 ESP Formula 5W-30 that does. Is this correct?
    My main question is - where can I buy the ESP version? My local (ACT) Supercheap and Autobarn only have the 'ordinary' one and don't seen to know about the other.
    Thanks in advance.
    From your local Mobil oil distributor, the good price is around $240 inc GST for 20L drum. There is also Penrite Enviro+ 5W30 in 5L or 1L bottles, that is VW approved and cost around $60 inc GST(for 5L) if you shop around.
    Jan 2009
    I believe almost every Audi/Seat/Skoda/Volkswagen*, as well as BMW, Mercedes and Porsche, require an oil with a high temperature / high shear (HTHS) viscosity of > 3.5 mPa.s
    Luckily, there is a quick method of determining this. If the oil meets either ACEA A3/B3, A3/B4, C3, or C4, it has a HTHS of >3.5. Mobil 1 ESP Formula 5W-30 has a HTHS of 3.56, so it is perfectly acceptable.
    If it meets either ACEA A1/B1, A5/B5, C1, or C2, then the HTHS is <3.5. Mobil 1 5W-30 has a HTHS of 3.06, so that means we cannot use it, as it is too thin.
    As you can see, it's not as simple as using any 5W-30 oil. But frankly, I'm not too sure if the average consumer can be bothered to know all this! I suppose the safest option is to use oils with VW approvals.
    It would be convenient if Mobil sold it here in 4L or 5L bottles like they do in Europe, but it'll certainly be much better value buying in bulk anyway, as indicated by Transporter. Send Mobil an e-mail and they'll point you to your nearest distributor.
    *except for engines that call for VW 503.00/506.00/506.01
    Jun 2006
    Sunshine Coast
    So what is suitable for the 506.00, can the 507.00 be used in that diesel? Is the number ranking backwards compatible i.e the higher the number covers the lower number.?
    2018 Skoda Superb TDI
    2010 Skoda Superb TDI
    2009 Golf VI 118 TSI
    2006 Multivan TDI SOLD
    Adelaide hills, SA
    Quote Originally Posted by coastie View Post
    Yes, the 504.00/507.00 supersedes all previous specifications except Unit Injector (PD) R5/V10 diesels engines made before 2006 and without DPF which must use VW506.01
    Jan 2009
    It seems there's always an exception when it comes to VW oil specs.
    I should clarify that I just wanted to cover all bases, as unlike all the other VW oil specs, I believe that 503.00/506.00 and 503.00/506.00/506.01 are the only two that specify a HTHS of < 3.5 (min. > 2.9)
    In any case, 504.00/507.00 does indeed supersede all previous specs, except (there's that word again) the R5 and V10 TDI engines up to 06/2006, which must use 503.00/506.00/506.01 regardless of service regime and with or without DPF.
    Edit - beaten!
    May 2010
    WA
    I find all of this very confusing. It kind of makes the price of a service worth it just so you don't have to worry about using the wrong oil!
    Golf VI GTI MY13 Candy white/ DSG/ Detroits/ tint/ reverse camera/ parking sensors
    2016 Skoda Octavia 162TSI RS Wagon (Silver/DSG/Tech pack/ Black pack)
    Jan 2009
    Problem is, getting your car serviced at the dealer is no guarantee that they'll use 504/507 oils.
    But anyway, those with FSI or TSI engines only need to look for 504.00/507.00 on the label - if it isn't there, don't buy/use it. Can't get much easier than that, really.
    May 2010
    WA
    After reading the things in this thread and others, looks like I'll try some Penrite enviro+ 5W30. It appears approved for the 118TSI and people here seem to think it's pretty good. Can get it from a couple of places in Perth.
    Question though- If you have have your car serviced somewhere and need an oil change, will they use oil that you supply if you ask them to?
    Thanks
    Jan 2009
    If they don't, then that's reason enough not to get your car serviced there.
    Perth
    Quote Originally Posted by Diesel_vert View Post
    Eg, the local VW dealer uses Mobil Super S 10w40 in Petrol cars however it is a VW 505.00 (Diesel spec) compliant oil
    ps I've always wanted to use that smilie - excuse the irrelevance
    MY08 Blue Graphite GT TSI DSG
