Results 1 to 10 of 11
Thread: Which brand of diesel?
rory Which brand of diesel? 21-01-2011, 08:20 PM
William_Foster Anymore feedback other users... 20-02-2011, 08:36 AM
Greg Roles Caltex Vortex is highly... 20-02-2011, 10:05 AM
William_Foster Thanks Greg! 20-02-2011, 10:20 AM
Russ59 I agree with Greg, stay away... 20-02-2011, 10:35 AM
Transporter I use only BP in Adelaide it... 20-02-2011, 11:05 AM
TDI DSG Any particular recomendations... 20-02-2011, 11:07 AM
Transporter WURTH CRD Fuel Additive and... 20-02-2011, 11:22 AM
    Jan 2008
    Sunshine Coast
    Caltex Vortex is highly recommended, virtually as good as BP. Shell doesn't have a premium diesel, but it should still be heads and shoulders over the Woolies and no name servos for consistency. Premium diesels have higher cetane numbers, but this does not correspond to premium petrol in normal cars, which can advance or retard timing to suit, a diesel goes bang when the fuel is injected. The main thing is consistency, low chance of water or the dreaded algae, and the fact they have cleaners added to help keep injectors at their peak. It's these latter cleaners I would attribute the Hilux difference mainly to. Interesting test all the same!
    Sep 2010
    Thanks Greg!
    6R Polo TDI; DSG
    Jun 2008
    South Coast N.S.W.
    I agree with Greg, stay away from the cheap servos, one dose of crap fuel and it could see the end of the engine. I have had my GT TDI since new and it has only ever been fed either Shell or on occasions when I'm near a BP servo I'll fill up with BP. I have used a Cetane boost additive but IMHO it made little or no noticeable difference to performance or economy. William congrats on the purchase and welcome to the Darker side (Diesel / Oilers) hopefully VW will have dealt with some of the issues which have and are still affecting some earlier model TDI's. Best of luck with the new Polo
    Russ
    2005 Subaru Outback 3.0 R Premium
    Adelaide hills, SA
    I use only BP in Adelaide it is probably the best fuel. The cleaning additives added to the diesel fuel by oil companies could be well used up once they go in the underground tanks and clean those first, that's why I always use additive with every fuel up. When buying diesel fuel additive make sure you get the one that is suitable for CRD, some diesel additives will brake down under the pressure in CR hi-pressure pump and will do no cleaning in the injectors.
    Sep 2006
    Any particular recomendations for CRD compatible products ?
    Adelaide hills, SA
    Quote Originally Posted by TDI DSG View Post
    WURTH CRD Fuel Additive and many others, more in this thread: http://www.vwwatercooled.org.au/f28/...ean-51614.html
    Sep 2006
    Thanks for that - just went to see if what is in the shed was CRD specific - chemtec has no mention CRD on the bottle.
