I used it once when BP had run out.
No noticeable difference to performance or economy
Has anyone used United Petrolium's Boost98 petrol in their MkV GTI?
If so, how does it compare with other 98RON fuels?
Did you notice any difference in performance/smoothness/mileage?
Many thanks
2018 Golf GTI, Manual - gone.
2017 Golf 110tsi Trendline, manual (gone - gladly)
2007 Golf GTI, Manual, (gone - sadly)
1978 Golf GLS; 1972 Superbug, (memories)
2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
2023 T-ROC R - Sunroof, Black Pack, Beats Audio
I finally tried a tank of Boost 98. Compared to BP Ultimate, no performance difference that I could notice, apart from a slight "hunting" on low boost.
Fuel economy was approx. 5% worse.
Overall I was pretty impressed. Don't know what it would do to fuel lines etc. over prolonged use, but VW said it's OK to use, so there must be a fair safety margin there.
I'll probably use it again - mainly because the local BP distributor screws us mercilessly on Ultimate pricing.
in theory, any alcolhol contained in the fuel will generally strip built up laquer type deposits from the fuel system.... laquer type deposits tend to be laid down by fuels not containing any alcohol componenent. so, there could be some short term problems depending on the cleanliness of the fuel system it goes into, and how long the ethanol is in there... so, theoretically, no problems with you new-ish car... and if you have some depostis to be cleaned out, they will be caught by the filter.
however, you just never quite know what is in any petrol you fill up with... personally i think its got more to do with the particular station you fill up at more than anything else, because the cleanliness (or lack thereof) of the fuel stations pump and tank system can cause real problems.
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
check this thread
http://www.vwwatercooled.org.au/newf...ght=fuel+brand
2009 Tiguan TDI and 2007 Passat TDI
