Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: Biodiesel and your new TDI.
    Adelaide hills, SA
    Some people on this forum think that I'm "antibiodiesel" well I'm not more antibiodiesel than the article in the link below.
    "Before you fill up your new TDI fuel tank with biodiesel".
    http://www.dieselpowermag.com/tech/g...nty/index.html
    http://www.google.com.au/url?sa=U&st...ZF1lYM3MnrfM-Q
    Nov 2008
    I believe the manual gives just such a warning but also permits the use of biodiesel which meets the appropriate fuel standard. (In short, B5.)
    Provided we are not duped by the oil companies, we shouldn't have a problem in this country.
    Feb 2008
    Richmond, VIC
    but now with diesel sitting at under $1.40 a litre and dropping more each day its becoming less of a saving. the risks far outweigh the gains IMO.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    Jan 2008
    Sunshine Coast
    Well the day my warranty runs out, I hope to never use Dino again.
    Sure you need to know what you are doing, but a properly set up car and biodiesel plant is definately my future. Dutchaussie is writing a book of his european experience, and I'm on the "want to purchase list". It's WHY I'm planning on hanging onto this car long term, and I can't think of a greater joy than to be able to drive past servo's and stick it to the man fuel wise.
    Shame they will still get the oil use!
    Jul 2007
    Blackburn South VIC
    Quote Originally Posted by cogdoc View Post
    Thats what i had hoped to do - there's a servo on Middleborough Rd not far from Burwood highway here in Melb., that sells biodiesel. Put through a few tanks - by the time the second tank was 3/4 of the way empty it was getting hard to start. (this was after topping up occasionally with BD and changing the filter). Went back to dino after 1 tank was back to easy starting.
    There is obviously a quality problem, my hunch is that unless you have BD that is up to a standard the quality may be suspect ie use no more than 5%. The problem is where was the base stock from? Oils, tallow? Was it washed properly?
    Unless u do it yourself, without testing you don't know what you have.
    Regards
    David
    Mar 2009
    Wagga Wagga
    Making biodiesel is really easy:
    -Filter fryer oil with a calico bag
    -Dissolve napthaline (crushed moth balls) into it
    -Filter again
    -QED
    My NA 2.0L 8v Mk3 Golf is faster than my 174kw twin turbo Supra. V8 utes and over modified Skylines hate being overtaken by old Golfs
    Jan 2007
    South Australia
    One of the forum members here powers his vehicle with Biodiesel and I think he makes it to.
    No problems...........so far to my knowledge.
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Adelaide hills, SA
    Quote Originally Posted by phaeton View Post
    I need a bit more prove than one member here and there to experimenting with his car before I would use biodiesel.
    Something like driving 200,000km using the biodiesel only and under different driving conditions in different climates on more than just one car, than
    after that 200,000km dismantle the engine and check the wear on the components and compare to the one driven on the petroleum diesel.
    20 engines in the testing like that could give some reasonably accurate data.
    But the problem is that the quality of the diesel fuel is not guaranteed, so even such test wouldn’t be accurate.
    P.S. Buying biodiesel instead petro diesel when there is not saving (actualy the engine is using more of it) is non sence.
    Any car fitted with DPF cannot use biodiesel anyway.
    Jun 2007
    central coast. Lake Macquarie. (Not Port Macquarie.)
    Quote Originally Posted by hokenmk3 View Post
    -Filter again
    -QED
    Dutch aussie and a few others make there own with no complication.
    I would be interested to know there thoughts on your Bio recipe as I think its a
    bit more complicated than that to make.
    Have you actually tried this recipe.
    Mar 2009
    Wagga Wagga
    Quote Originally Posted by neil View Post
    Yeah but only in a 4.2L Nissan Patrol so there is no hurting that thing. It runs on just the oil with no moth balls so it is not really any indication... although without the moth balls chewed the fuel filter and with the mothballs seemed not to.
