I believe the manual gives just such a warning but also permits the use of biodiesel which meets the appropriate fuel standard. (In short, B5.)
Provided we are not duped by the oil companies, we shouldn't have a problem in this country.
Some people on this forum think that I'm "antibiodiesel" well I'm not more antibiodiesel than the article in the link below.
"Before you fill up your new TDI fuel tank with biodiesel".
http://www.dieselpowermag.com/tech/g...nty/index.html
http://www.google.com.au/url?sa=U&st...ZF1lYM3MnrfM-Q
but now with diesel sitting at under $1.40 a litre and dropping more each day its becoming less of a saving. the risks far outweigh the gains IMO.
currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
Well the day my warranty runs out, I hope to never use Dino again.
Sure you need to know what you are doing, but a properly set up car and biodiesel plant is definately my future. Dutchaussie is writing a book of his european experience, and I'm on the "want to purchase list". It's WHY I'm planning on hanging onto this car long term, and I can't think of a greater joy than to be able to drive past servo's and stick it to the man fuel wise.
Shame they will still get the oil use!
Thats what i had hoped to do - there's a servo on Middleborough Rd not far from Burwood highway here in Melb., that sells biodiesel. Put through a few tanks - by the time the second tank was 3/4 of the way empty it was getting hard to start. (this was after topping up occasionally with BD and changing the filter). Went back to dino after 1 tank was back to easy starting.
There is obviously a quality problem, my hunch is that unless you have BD that is up to a standard the quality may be suspect ie use no more than 5%. The problem is where was the base stock from? Oils, tallow? Was it washed properly?
Unless u do it yourself, without testing you don't know what you have.
Regards
David
Making biodiesel is really easy:
-Filter fryer oil with a calico bag
-Dissolve napthaline (crushed moth balls) into it
-Filter again
-QED
My NA 2.0L 8v Mk3 Golf is faster than my 174kw twin turbo Supra. V8 utes and over modified Skylines hate being overtaken by old Golfs
One of the forum members here powers his vehicle with Biodiesel and I think he makes it to.
No problems...........so far to my knowledge.
- Ben
1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
2008 Jetta 2.0L FSI
I need a bit more prove than one member here and there to experimenting with his car before I would use biodiesel.
Something like driving 200,000km using the biodiesel only and under different driving conditions in different climates on more than just one car, than
after that 200,000km dismantle the engine and check the wear on the components and compare to the one driven on the petroleum diesel.
20 engines in the testing like that could give some reasonably accurate data.
But the problem is that the quality of the diesel fuel is not guaranteed, so even such test wouldn’t be accurate.
P.S. Buying biodiesel instead petro diesel when there is not saving (actualy the engine is using more of it) is non sence.
Any car fitted with DPF cannot use biodiesel anyway.
