![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
gldgti
Ahhh ha.
Where do i come from? I'm a mechanical engineer and car enthusiast.... I've always owned a diesel car and in the last 18 months i've run my mk3 turbo-diesel for 70,000km on 100% pump biodiesel. I have changed the fuel filter once in that time, change the oil every 6-7000km and have no evidence to suggest that this is inadequate. Infact, i would dispute your claim that you need to change the oil more frequently using biodiesel - its use produces less soot, and a well functioning injection system should not comtaminate the engine oil.
My father has been using 100% biodiesel (home-made) in a mk1 GLD and a mecedes 240D for 150,000km in the former case and 50,000km in the latter case. He claims over the time he's used Bio, the only disadvantages have been very cold winter morning starts (cured by fuel heater), and the fact he's had to replace the 30-yo pump seals with newer synthetic rubber components. I have yet to suffer any such disadvantage with my 1994 vehicle.
I certainly sympathise with those people who try a batch of bio and then end up with a big and expensive problem - but we both acknowledge that bio-diesel quality can be variable, and as such it is unsurprising that these kinds of incidents happen. I propose that as usual, the bad news is always far better publicised than the good, and that these cases occur in the minority.
Further - it is scientific FACT that biodiesel is, as a chemical, an effective cleaner and solvent for petrochemical deposits, and as such, gummy deposits formed by years of dino-diesel use are almost ALWAYS stripped out of the fuel system of a vehicle that begins using bio-diesel, and as such its that "first tank" syndrome of failure. It is not fair to put the failure of a fuel system due to ingestion or blockage by general garbage, on a perfectly good fuel that has cleaned (in an in-opportume manner) the fuel system. Am i saying this out of heresay? Not at all - In the 5 diesel vehicles that my father and i have run on biodiesel, we have witnessed this in every one. THe first month or so of operation sees a multitude of gunk come out of the system, until finally the system is clean and free of deposits and normal, trouble free operation is allowed.
I fail to see, how utilising a fuel with higher lubricity, cleaner and smoother burn and higher oxygen content could negatively impact on engine wear. In every diesel vehicle i have ever run on bio-diesel, i have always been able to observe a smoother running and slightly cooler running engine.
since its late, and i need to go to bed, i wont find any links for you to read up on... but if you google "From the Fryer to the Fuel Tank", you will find links to a very good book written Joshua Tickell. I hope that just because "you arent interested" in the work of simple minded forum users "backyard experiements", that you will be able to take on board and perhaps consider that i might have some idea about this stuff.
One more thing - VW are far more likely to warn against using biodiesle in australia, not because they have tested it and don't think you should use it, but because they dont want to pay for all the repairs on vehicles that have been subjected to the things we have already spoken about.
for now, peace out.
