Results 1 to 7 of 7
Thread: The best oil test
    Jul 2010
    Robina Gold Coast
    The best oil test
    http://www.animegame.com/cars/Oil%20Tests.pdf
    There is really a lot of difference in oils >
    Adelaide hills, SA
    Re: The best oil test
    Hmm, as they say in that article, when you buying that oil you buyin a lot of chemicals in it (additives), but there is much more to the oil than keep the moving parts apart. So, the oil with the smallest scar doesn't have to be the best oil for your engine.
    Sent from my GT-I9505
    Aug 2012
    Perth WA
    Great article. Thanks for the link.
    Although they don't test 504/507 oils and you can't directly compare, it is interesting to note that some of the more fancied and expensive brands did poorly.
    I would have normally chosen Castrol as being VW endorsed and possibly original fill, but now Penrite is looking like a front runner.
    Adelaide hills, SA
    Any of these oils in that test, even the one with the biggest wear scar will protect the engine for hundreds of thousands kilometres if you keep the oil clean and change it on time.
    Clean oil and good oil filtration is the key to the long lasting and the reliable engine.
    Pacific Paradise QLD
    Quote Originally Posted by Amalgam View Post
    +1 for Penrite
    Mar 2011
    +1 for Penrite
    Penrite FTW!
    Dec 2012
    Sutherland Shire, Sydney
    Indeed - I have a 2006 Nissan 350Z with 249,000km on the clock
    The engine is still pulling strong and does not slap or ping when laboured
    The original owner changed the oil every 5,000km
    Note - the oil analysis testing on BobIsTheOilGuy also showed poor results for the Motul, even the Purple stuff did not impress
