Results 1 to 10 of 13
Thread: 2% Ethanol mandatory in NSW (September)
    Feb 2007
    http://www.smh.com.au/news/NATIONAL/...390531377.html
    I've got a new VW, which VW Australia have said will run satisfactorily on ethanol blended fuel up to 10%, and so am not unduly worried at this at all.
    However, I'm not quite so sure how older cars like the Mk1 and Mk2 Golf are going to cope with the ethanol - this may be of Watercooled interest
    brackie Guest
    tiny %age
    I reckon 2% won't cause too many problems.
    Nov 2005
    prob not.. just having you car sit there, for a couple of weeks and have the ethanol rust your head because it is a huge rust helper
    wabit
    brackie Guest
    Ethanol and other additives to petrol
    I think that this web-sourced article is referring to much larger %ages than 2%, however....
    "Fuel ethers and ethanol are more effective octane components since they deliver higher octane numbers than aromatics and therefore require less volume to deliver the same amount of octane. However, ethanol cannot be utilised without difficulties by the refiners in petrol because of its high water solubility, which effectively prevents its use in the distribution system for petrol. Ethanol has also a high, non-ideal blending vapour pressure which tends to knock off some other, light, low-boiling hydrocarbons from the gasoline blend in order to meet the volatility regulations. Technically, and because of its higher cost, ethanol is not really a viable alternative."
    Source: http://www.efoa.org/oxygen.html#4 on 14th May 2007
    There's plenty of info on the 'net. Just do a search.
    This has the makings of an interesting and ongoing thread so I'm moving it to "Fuels and Lubricants". Dutchaussie....Are you ready to comment??
    gpk_gti Guest
    so,my understanding was ethanol condenses more water and makes engines rust,basically. am i miss understanding?
    Oct 2005
    Nowra, NSW
    yep, ive seen a head that was rusted out from ethanol not pretty. This is how i had it explained to me from an engine re-conditioner, remember school science getting water from metho? thats the same with ethanol. It also has a different mixture compared to normal fuel, so on a carbied car the air fuel mix can go right out and the engine can lean right out and... well you know what happens then. I really don't want to touch the stuff.
    On newer cars you shouldn't have any issues though as the ecu will handle a lot of those problems except it rusting your head!
    brackie Guest
    Properties of ethanol
    Ethanol is water-soluble and hygroscopic. In other words it dilutes in water and attracts and absorbs any free water or water vapour around it. This probably wouldn't be a problem in a closed fuel system in a car, however it's a bit of a worry in a servo's tanks as they are vented.
    2% is 20mL in a litre and this isn't much ethanol by proportion (imagine 4 teaspoons) so I personally can't see much potential for disaster. However as the proportion increases so does the risk.
    If my memory serves me correctly Brazil had 100% ethanol Beetles. Obviously the whole fuel system was redesigned to cope with the fuel, however if again my memory serves me correctly there were so many problems that they gave it up.
    syncro Guest
    Quote Originally Posted by brackie View Post
    They reintroduced it across the VW range with special engines.
    The ECU cannot adjust by itself for ethanol, so the mixture will be wrong.
    We will now cut down many hectares of forest to grow crops for ethanol production. I hate half wit greenies
    sydney/ cessnock
    Cool i had no problems over an15k year
    i had a mk1 1.8 which i ran as my daily driver did about 15k that year and always filled up with 10% ethonal never had any problems his is only a small time scale though
    owned a number of mk1 golfs have a collection of spare parts project golf is a 78 2 door
    Jul 2007
    Canberra
    Brackie: They didn't give it up.. the project was started in 1973 after the big oil-crash with sky-rocketing prices. Over the mid-80s and early 90s popularity in E100 cars dropped significantly due to very low oil prices. However, these cars have been resurected in the past few years for two reasons: a) increasing oil prices, and b) because most new cars sold now are dual-fuel (as in E100 and gasoline). In fact, 55% of transport in Brazil is now using fossil-fuel alternatives.
    Syncro: With increasing petrol prices, current grain-crops in Australia can provide a minimum of 10% of our fuel usage in Ethanol at approximately 80c per litre. This just means that we've got to reduce our grain exports. Of course there are issues of fuel vs food security if Ethanol production is increased, which is why alot of research is going into alternative crops and biofuel production techniques (mainly Lignocellulosis). Alternative crops (or in fact, feedstocks) which may soon power our cars include waste from households, forestry, farming (crops & animal), etc..
    Australia is actually a long way behind most 1st world countries (including the US surprisingly). But its mainly in Europe where the big movers are. Check out Saab's E85 compatible cars which account for a large percentage of the new car market in Sweden.
    Anyways.. enough aimless rambling..
    Damien
