Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: 2.0 Tdi Oil
  1. #21
    sweet then ill get onto it
  2. #22
    Sep 2006
    My dealer tells me that they are using an imported castrol product not available through australian dist - I think it was txt3 ? He also says the car comes from the factory with the "running in oil" that should be left in untill at least 5000 klm. My 2.0 has 2700 klm's up with no oil usage at all yet - so I have a while to decide if to change the oil or not - and what to use if I do !
  3. #23
    May 2006
    Adelaide South Australia
    Motul 4100 turbolight
    Quote Originally Posted by Seano
    Caltex Havoline Synthetic 5W-40 http://www.caltex.com.au/products_oil_detail.asp?id=323 Volkswagen, 502.00 and 505.00 (SAE 5W-40)
    TITAN SUPERSYN SL LONG LIFE PLUS 0W30 http://www.fuchs.com.au/html/passeng...ngine_oil.html A full synthetic low viscosity SAE 0W30 engine oil, specifically formulated to meet the requirements and demands of late generation VW and AUDI vehicles requiring specification VW 503 00, VW 506 00 & 506 01.
    Another oil to add to this list is Motul 4100 turbolight 'Technosynthese Synthetic' SAE 10W-40 --- Car manufacturers approvals VW 501 01 / 500 00 / 505 00, M.B etc. This is a euro oil made in France & was told a premium product.
    Who knows if that is true.
    It is sold in S.A. by Autobarn ---$44.95 for 5 litres.
    Rob
  4. #24
    Sep 2006
    After speaking to my dealer's service dept again I was given a different story as to the brand and spec of the oil they use in the current TDI engines - this is a real concern as there are not a lot of VW dealers around and the ones that are should know details like this backwards - isnt that why they try to convince us to go with overpriced dealer servicing ? Asked about a 7500 klm oil and filter change - approx $180 - one filter and less than 4 ltrs of oil. I have not performed an oil change on a TDI but surely it couldnt take more than half an hour ?
    Do VW honour the warranty if you dont use a dealer servicing ?
  5. #25
    Jul 2005
    After a lot of research with my Fuchs rep, each new VW engine needs a special oil. The direct injection ( petrol and dsl) need oil that doesn't leave deposits on the injectors and also must meet VW specs if your is serviced by an independant workshop.We carry 6 different oils (1 mineral and 5 synthetic) to cover all the VW and Audi cars that we service and have never had a car knocked back for any kind of warranty work by the dealers.Just make sure that the proper spec oil is used (whatever brand) and there should be no problems.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
  6. #26
    brackie Guest
    Definitive
    Thanks for the qualified answer, Peter... But the question remains:
    If the sump is filled with "running in oil" at the factory, and the car is using ULSD and operating in average or normal conditions, do we leave it in until 15,000km or change it to a different oil at 7,500km?
  7. #27
    syncro Guest
  8. #28
    Apr 2006
    sydney australia
    Cool Service Interalz
    The recomendation from VW Australia is for the first service to be carried out at 15000 km or 12 months which ever occurs first!
  9. #29
    just topped up the polo with 5W-40 Shell Oil
  10. #30
    Will pick up my New Comfortline 2.0 TDi tomorrow. And have been doing some home work on Oil's for the motor...
    found this http://www.penrite.com.au/html/s02_a..._id=55&dsb=581
    Looks to be meet the specs of 505.01/505.00/506.00/506.01 which is right for the TDi's long life oil's.
    Repco down the road from work sell it in 10 Lt drums.
    Hope this maybe off some use, to you good people...
    Edited added more spec's.
    Mark V 2006 MY07 2.0Tdi Comfortline 6spd/Man
    Mark IV 2001 1.6L (SOLD)
