no results that I can see
Hi All,
Just bought a 2007 manual 2.0(t)FSI Eos at auction for a good price with 171tkm.
Have also bought a vagcom for the first time. Did the autoscan and the results are posted below. Anyone that can share a light on the issues? I have sorted the roof fault and cleared the code. The DV fault I assume could be an old one, as it is from 20tkm ago, however probably worth upgrading to the new revision as well soon.
The car however seems to shudder a fair bit upon startup at idle. Could this be coil packs (motor/exhaust has no change in sound) or is could it be the PCV valve that needs replacing? Have not taken the car for a drive yet, as it just got delivered and is stored in the garage.
Lastly, I read that there a lot of issues with the AC on these year models. Mine is not blowing any cold air. Does not make any noises though and blows air on all speed settings, just not cold at all.
Any pointers would be appreciated. thanks. Danny
Sorry, codes below
Below the codes of the first scan, before the resetting of roof and engine code.
Regarding the window scan, is this normal not to be detected on the Eos, due to a different window regulator switch etc.? I noticed that the small rear windows go down, but not up if one uses the designated switches for them. (they work fine if i use the master switch that applies to all four windows)
Saturday,06,February,2016,12:09:43:53046
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WVWZZZ1FZ7V026903 License Plate:
Mileage: 171440km-106527mi Repair Order: 1st scanVW EOS
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 55 56 62 72 76
VIN: WVWZZZ1FZ7V026903 Mileage: 171440km-106527miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
26-Auto Roof -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1Q0 907 115 C HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH15--- Serial number: VWX7Z0FN3N88K0
Coding: 041C004318070160
Shop #: WSC 00560 959 86236
VCID: 2C5172778FC40141E33-8079
1 Fault Found:
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 189
Reset counter: 255
Mileage: 152488 km
Time Indication: 0
Date: 2000.00.00
Time: 16:18:29
Freeze Frame:
RPM: 2321 /min
Load: 11.0 %
Speed: 95.0 km/h
Temperature: 84.0∞C
Temperature: 21.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004834
Shop #: WSC 00020 000 00000
VCID: 73E3A90B127A1EB9629-8026
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1Q0 907 044 A HW: 1Q0 907 044 A
Component: ClimatronicPQ35 093 0101
Revision: 00093002 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 2B53716B8ACA0679EA9-807E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006292474
Coding: E78E8F0700041500470A00000F000000000A5D035C0001
VCID: 6CD1B2774F44C141A33-8039
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 081106 020 0501
Coding: 00038805
Shop #: WSC 00020
Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
Component: RLS 131106 020 0105
Coding: 00208933
Shop #: WSC 00020
Address 15: Airbags Labels: 1Q0-959-655.lbl
Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
Component: 65 Airbag VW8C 0180
Revision: 92009018 Serial number: 003B30014WLW
Coding: 0013877
VCID: 3A7D442F7590AFF161F-806F
Subsystem 1 - Serial number: 6332SRB404125199T
Subsystem 2 - Serial number: 6342SRB4042D8DB5C
Subsystem 3 - Serial number: 637 RB4 8
Subsystem 4 - Serial number: 638 RB4 9
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AK HW: 1K0 953 549 AK
Component: J0527 032 0070
Coding: 0002021
VCID: 7BF3812B3A2A56F93A9-802E
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1Q0 920 873 HW: 1Q0 920 873
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWX7Z0FN3N88K0
Coding: 0023703
Shop #: WSC 00560 959 97413
VCID: 6FEBA57B7E523A59861-803A
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106A1788EE
Coding: 7D3F274007005001
VCID: 2F6B657BBED27A59C61-807A
Address 25: Immobilizer
Cannot be reached
Address 26: Auto Roof Labels: 1Q0-959-255.clb
Part No SW: 1Q0 959 255 B HW: 1Q0 959 255 B
Component: Verdecksteuergeraet 0622
Revision: 0032000K Serial number: 062930030
Coding: 0655362
VCID: 377B5D1B4682B2999E1-8062
1 Fault Found:
02805 - System Interference
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 4
Reset counter: 186
Mileage: 171445 km
Time Indication: 0
Date: 2000.00.00
Time: 10:18:23
Freeze Frame:
Voltage: 14.00 V
Voltage: 13.90 V
Voltage: 5.00 V
Error Code: 1
Address 42: Door Elect, Driver Labels: None
VCID: 55A7F793BCCE60896CD-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.070 H07 1806
VCID: 356757135C8E40898CD-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 80908A000186285B0804840560085E0380FC00
Shop #: WSC 30081 959 100517
VCID: 0303F9CB42DA2E39729-8056
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass.
Cannot be reached
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Part No SW: 5M0 907 357 A HW: 5M0 907 357 A
Component: AFS-Steuergeraet X014
Revision: H01 Serial number:
Coding: 2507011
VCID: 326D6C0FADE057B1A9F-8067
Subsystem 1 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul l 0002
Coding: 00000038
Subsystem 2 - Part No: 7L6 941 329 A
Component: AFS-Lst.-Modul r 0002
Coding: 00000038
1 Fault Found:
00496 - Sensor for Vehicle Leveling; Front
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 179
Time Indication: 0
Freeze Frame:
Voltage: 10.79 V
Speed: 0.0 km/h
ABS 1
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 195 D
Component: Radio BVX 013 0033
Coding: 0040402
VCID: 275B8D5B962222190E1-8072
1 Fault Found:
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1Q0 959 703 A HW: 1Q0 959 703 A
Component: Tuer-SG 004 1202
Coding: 0000128
Shop #: WSC 00020 000 1012544
VCID: 34616A1757F45981BB3-8061
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1Q0 959 704 A HW: 1Q0 959 704 A
Coding: 0000128
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1Q0 919 283
Component: 30 Einparkhilfe 0702
VCID: 72EDAC0F6D6017B169F-8027
End-------------------------(Elapsed Time: 02:39)--------------------------
The N249 I'd reset the fault and see what happens. If it does it again either get a GFB DV+ or the revised OEM unit.
I can't help with the window switches - sorry
vehicle levelling is probably the unit for adjusting the HIDs - assuming it has them. I think it's on the front left wheel. It's only done it once so probably a wait & see scenario
Thanks brad.
Will see if the dv code comes up again after clearing it.
Any idea on whether the rough idle at start up can be related to the pcv or most likely needs a good clean of the intake?
Any pointers on the aircon not blowing cold. compressor shot?
Will check the issue with the hid levelling. noticed the eos does not have the level adjusting wheel next to the light switch, as i had it with my jetta mk5.
Thanks
i'd think you've got a shedload of carbon build up on the intake valves. VW claims you can do an "Italian tune-up" style clean by maintaining more than 4000rpm for more than 20 minutes driving. This gets sufficient heat into the valve stems to burn off or shed carbon. I tried it a few months back and it felt no different but it can't hurt.
Try a chemical clean but nothing beats removing the intake & attacking it with picks, burrs & chemicals. Try Mr Muscle Odourless Oven Cleaner (green can) - it should be OK with Aluminium as it's non-caustic (which eats aluminium).
The AC could be simply lack of gas, the compressors at that time were shyte and prone to self-destructing but it might also be the valves on the end of the compressor. You'll need to do some googling to work it out and maybe visit an AC specialist. Shop around for a compressor (if needed) as prices vary by about 300%.
What did you pay for the EOS?
