Results 1 to 7 of 7
Thread: VCDS codes 2.0(t)FSI and rough idle on start up, no cold AC etc
    Jan 2014
    Hi All,
    Just bought a 2007 manual 2.0(t)FSI Eos at auction for a good price with 171tkm.
    Have also bought a vagcom for the first time. Did the autoscan and the results are posted below. Anyone that can share a light on the issues? I have sorted the roof fault and cleared the code. The DV fault I assume could be an old one, as it is from 20tkm ago, however probably worth upgrading to the new revision as well soon.
    The car however seems to shudder a fair bit upon startup at idle. Could this be coil packs (motor/exhaust has no change in sound) or is could it be the PCV valve that needs replacing? Have not taken the car for a drive yet, as it just got delivered and is stored in the garage.
    Lastly, I read that there a lot of issues with the AC on these year models. Mine is not blowing any cold air. Does not make any noises though and blows air on all speed settings, just not cold at all.
    Any pointers would be appreciated. thanks. Danny
    Erskineville, NSW
    no results that I can see
    Jan 2014
    Sorry, codes below
    Below the codes of the first scan, before the resetting of roof and engine code.
    Regarding the window scan, is this normal not to be detected on the Eos, due to a different window regulator switch etc.? I noticed that the small rear windows go down, but not up if one uses the designated switches for them. (they work fine if i use the master switch that applies to all four windows)
    Saturday,06,February,2016,12:09:43:53046
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 14.10.0.0
    Data version: 20141022
    VIN: WVWZZZ1FZ7V026903 License Plate:
    Mileage: 171440km-106527mi Repair Order: 1st scanVW EOS
    Chassis Type: 1F (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 26 42 44 46 52 55 56 62 72 76
    VIN: WVWZZZ1FZ7V026903 Mileage: 171440km-106527miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    26-Auto Roof -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 1Q0 907 115 C HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0040
    Revision: 5BH15--- Serial number: VWX7Z0FN3N88K0
    Coding: 041C004318070160
    Shop #: WSC 00560 959 86236
    VCID: 2C5172778FC40141E33-8079
    1 Fault Found:
    008801 - Boost Pressure Control Valve (N249)
    P2261 - 008 - Mechanical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 189
    Reset counter: 255
    Mileage: 152488 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:18:29
    Freeze Frame:
    RPM: 2321 /min
    Load: 11.0 %
    Speed: 95.0 km/h
    Temperature: 84.0∞C
    Temperature: 21.0∞C
    Absolute Pres.: 1010.0 mbar
    Voltage: 14.224 V
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0004834
    Shop #: WSC 00020 000 00000
    VCID: 73E3A90B127A1EB9629-8026
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1Q0 907 044 A HW: 1Q0 907 044 A
    Component: ClimatronicPQ35 093 0101
    Revision: 00093002 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 2B53716B8ACA0679EA9-807E
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000006292474
    Coding: E78E8F0700041500470A00000F000000000A5D035C0001
    VCID: 6CD1B2774F44C141A33-8039
    Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer 081106 020 0501
    Coding: 00038805
    Shop #: WSC 00020
    Subsystem 2 - Part No: 1K0 955 559 AB Labels: 1K0-955-559-AF.CLB
    Component: RLS 131106 020 0105
    Coding: 00208933
    Shop #: WSC 00020
    Address 15: Airbags Labels: 1Q0-959-655.lbl
    Part No SW: 1Q0 959 655 A HW: 1Q0 959 655 A
    Component: 65 Airbag VW8C 0180
    Revision: 92009018 Serial number: 003B30014WLW
    Coding: 0013877
    VCID: 3A7D442F7590AFF161F-806F
    Subsystem 1 - Serial number: 6332SRB404125199T
    Subsystem 2 - Serial number: 6342SRB4042D8DB5C
    Subsystem 3 - Serial number: 637 RB4 8
    Subsystem 4 - Serial number: 638 RB4 9
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AK HW: 1K0 953 549 AK
    Component: J0527 032 0070
    Coding: 0002021
    VCID: 7BF3812B3A2A56F93A9-802E
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1Q0 920 873 HW: 1Q0 920 873
    Component: KOMBIINSTRUMENT VDD 1610
    Revision: V0003000 Serial number: VWX7Z0FN3N88K0
    Coding: 0023703
    Shop #: WSC 00560 959 97413
    VCID: 6FEBA57B7E523A59861-803A
    Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H12 0170
    Revision: H12 Serial number: 3300106A1788EE
    Coding: 7D3F274007005001
    VCID: 2F6B657BBED27A59C61-807A
    Address 25: Immobilizer
    Cannot be reached
    Address 26: Auto Roof Labels: 1Q0-959-255.clb
    Part No SW: 1Q0 959 255 B HW: 1Q0 959 255 B
    Component: Verdecksteuergeraet 0622
    Revision: 0032000K Serial number: 062930030
    Coding: 0655362
    VCID: 377B5D1B4682B2999E1-8062
    1 Fault Found:
    02805 - System Interference
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 186
    Mileage: 171445 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 10:18:23
    Freeze Frame:
    Voltage: 14.00 V
    Voltage: 13.90 V
    Voltage: 5.00 V
    Error Code: 1
    Address 42: Door Elect, Driver Labels: None
    VCID: 55A7F793BCCE60896CD-8000
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.070 H07 1806
    VCID: 356757135C8E40898CD-8060
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0203
    Revision: 00020000 Serial number: 00000000000000
    Coding: 80908A000186285B0804840560085E0380FC00
    Shop #: WSC 30081 959 100517
    VCID: 0303F9CB42DA2E39729-8056
    Subsystem 1 - Component: Sounder n.mounted
    Subsystem 2 - Component: NGS n.mounted
    Subsystem 3 - Component: IRUE n.mounted
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
    Part No SW: 5M0 907 357 A HW: 5M0 907 357 A
    Component: AFS-Steuergeraet X014
    Revision: H01 Serial number:
    Coding: 2507011
    VCID: 326D6C0FADE057B1A9F-8067
    Subsystem 1 - Part No: 7L6 941 329 A
    Component: AFS-Lst.-Modul l 0002
    Coding: 00000038
    Subsystem 2 - Part No: 7L6 941 329 A
    Component: AFS-Lst.-Modul r 0002
    Coding: 00000038
    1 Fault Found:
    00496 - Sensor for Vehicle Leveling; Front
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 179
    Time Indication: 0
    Freeze Frame:
    Voltage: 10.79 V
    Speed: 0.0 km/h
    ABS 1
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 195 D
    Component: Radio BVX 013 0033
    Coding: 0040402
    VCID: 275B8D5B962222190E1-8072
    1 Fault Found:
    00877 - Treble Speaker Rear Right (R16)
    011 - Open Circuit
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1Q0 959 703 A HW: 1Q0 959 703 A
    Component: Tuer-SG 004 1202
    Coding: 0000128
    Shop #: WSC 00020 000 1012544
    VCID: 34616A1757F45981BB3-8061
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1Q0 959 704 A HW: 1Q0 959 704 A
    Coding: 0000128
    Address 76: Park Assist Labels: 1K0-919-283.lbl
    Part No: 1Q0 919 283
    Component: 30 Einparkhilfe 0702
    VCID: 72EDAC0F6D6017B169F-8027
    End-------------------------(Elapsed Time: 02:39)--------------------------
    Erskineville, NSW
    The N249 I'd reset the fault and see what happens. If it does it again either get a GFB DV+ or the revised OEM unit.
    I can't help with the window switches - sorry
    vehicle levelling is probably the unit for adjusting the HIDs - assuming it has them. I think it's on the front left wheel. It's only done it once so probably a wait & see scenario
    Jan 2014
    Thanks brad.
    Will see if the dv code comes up again after clearing it.
    Any idea on whether the rough idle at start up can be related to the pcv or most likely needs a good clean of the intake?
    Any pointers on the aircon not blowing cold. compressor shot?
    Will check the issue with the hid levelling. noticed the eos does not have the level adjusting wheel next to the light switch, as i had it with my jetta mk5.
    Thanks
    Erskineville, NSW
    i'd think you've got a shedload of carbon build up on the intake valves. VW claims you can do an "Italian tune-up" style clean by maintaining more than 4000rpm for more than 20 minutes driving. This gets sufficient heat into the valve stems to burn off or shed carbon. I tried it a few months back and it felt no different but it can't hurt.
    Try a chemical clean but nothing beats removing the intake & attacking it with picks, burrs & chemicals. Try Mr Muscle Odourless Oven Cleaner (green can) - it should be OK with Aluminium as it's non-caustic (which eats aluminium).
    The AC could be simply lack of gas, the compressors at that time were shyte and prone to self-destructing but it might also be the valves on the end of the compressor. You'll need to do some googling to work it out and maybe visit an AC specialist. Shop around for a compressor (if needed) as prices vary by about 300%.
    What did you pay for the EOS?
    Jan 2014
    Thanks brad for the helpful tips.
    Pm coming
