Results 1 to 7 of 7
Thread: Tyre Noise
    Aug 2008
    Brisbane Qld
    Question Tyre Noise
    Has anyone had issues with tyre noise from the Continental Tyres that are fitted to my EOS. They are extremely noisy on smooth bitumen roads and as you slow down under brakes. Any suggestions?
    Regards
    Brooksi
    Essendon
    Not at all. The exact opposite. It's one of the quietest cars I've driven.
    Sorry I'm not much help.
    Sunroof // ICT Tint // Seats // Steering wheel
    Taree NSW
    Quote Originally Posted by brooksi View Post
    Regards Brooksi
    Hi Brooksi,
    Given the relatively small number of Australian Eos owners who are sufficiently interested in getting involved with forum discussions, the response to your request may be under-whelming.
    Suggest you should also lodge your request on the international Eos forum and I am certain you will get a number of responses from owners with the same tyres as you.
    http://www.vweosclub.com/forums/
    Hope this helps - waiting to see what tyres are on my partner's car when it is delivered.
    SS
    Carer for my partner's Eos 2.0 TDI DSG MY09 Candy White/Cornsilk Beige leather trim.
    Regards
    Brooksi
    I've seen quite a few MK5 Golf's, Jetta's & some EOS' with this problem.
    It's a normal trait of the Conti's unfortunately. They also like to go out of round on the back too!
    Noisy tyres
    I have found that making sure your pressures are on the high side for a few months seems to get rid of the noise.... the noise mine started making at around 20,000kms was a whining noise loudest at certain speeds - this seems to have reduced after pumping my tyres up to 38PSI for a few thousand K's.... have 18"s......
    A
    Eos Individual 2.0TDi Wheat Beige DSG BiXenon
    Fiat Punto Sport 1.9TDi Red and Zippy
    Jun 2008
    Wollongong, Oz
    Run your hand over the surface of the tyre. Is it knobbly? That is, are certain parts of the tread raised?
    If so, then try roating the tyres front to back, and ensure you are not running low pressures.
    MY22 Tiguan 162 Elegance
    Sound and Vision , Sunroof packages
    Fireball Graphene Butterfly ceramic coating
    Thinkware U1000 dash cams
    Aug 2008
    Brisbane Qld
    Red face
    Thanks all for your comments and suggestions. I would have been back to you all earlier but I have been out of town
    regards
    Brooksi
