Results 1 to 7 of 7
Thread: Roof Failure
    Roof Failure
    When putting the roof down the side rails fail to unlatch from the windscreen header rail and I get the message 'System Error - Close Convertible Roof'.
    It is booked in for a service on Monday so hopefully they can fix it then.
    Anyone else had a similar problem?
    125i Sport Convertible | Alpine White | Coral Red | M261 18" | Debadged | Harman Kardon | Extended Mobile Phone Connectivity
    On further investigation the interior fabric lining for the passenger side 'c' pillar is fouling the cover which sits outboard of the rear passenger seat and will not allow it to open and hence the roof stops. I have moved it a couple of times manually and the roof opens normally but without the human assistance the roof will not fully open. Hopefully it is an easy fix.
    Problem was solved with an adjustment to the hinges to rectify trim being caught on C-Pillar according to my paperwork.
    Dec 2007
    Brisbane, Southside...
    Covered under warranty I hope?
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Yes Sir!
    A 3 year lease that finishes on the day the warranty finishes.
    Dec 2007
    That's good. If you're planning on keeping the car after the lease for longer, I'd be thinking about the extended warranty maybe...
    It's always disheartening hearing about these things.
    Cheers,
    Trent
    Taree NSW
    Quote Originally Posted by Treza360 View Post
    Cheers,
    Trent
    No - this is not always the case.
    Think about the products you have owned over the years that had problems - do you remember that there was a problem or do you really remember how well [or badly] it was fixed?
    Most mechanical devices will have problems at some time in their life so after-sales support must always be a consideration in the purchase decision.
    In this case, I suggest it is really a success story as the problem was resolved quickly and effectively. If the car had been out-of-warranty, it appears to me that the service charge from a reputable dealer would not have been expensive perhaps 30 minutes labour [I fixed a similar problem on our Eos in 5 minutes with some white Lithium grease as the flap was binding and no adjustment was required].
    Carer for my partner's Eos 2.0 TDI DSG MY09 Candy White/Cornsilk Beige leather trim.
