Results 11 to 20 of 23
Thread: Hi there (2009 eos blk) oil question
    Feb 2010
    MILPERRA NSW
    Quote Originally Posted by Rob Burns View Post
    It is normal. Cars these days are designed with some oil consumption in mind. They use low friction piston rings which helps improve fuel economy and power with the one drawback being some oil consumption.
    Now i am confused a friend of mine has a WRX suburu 2ltr turbo and does not have to use oil between the services,debbie
    Adelaide hills, SA
    Hi debbie,
    if that car would be mine I'd go to the dealer and complained about the oil consumption let them do the excessive oil consumption test, that way it would be documented, if later there is more problems with the engine because of that.
    Yeah and get the record of it, if you go in.
    Apr 2009
    Quote Originally Posted by debbie View Post
    The car was brought new,
    being a lady I drive normal dont race or drive hard at all.
    then it went for the 7,500 service safety check
    I hadnt checked the oil at that time and no light had come on.
    we didnt get to 15,000 as the oil light came on at 12656 and we had to add 1ltr of oil to the car.We took it back then Iasked the VW service centre if it was normal for this to happen and was told that its normal oil use .
    we are roughly putting in 1ltr per 3,000 km city driving and they are still telling us its normal consumption because its turbo petrol.
    No oil leaks at all.
    i dont know if the fact thats its turbo petrol should make a difference. I had a focus XR5 turbo for two years from new and never used a drop. My current v6 highline has almost 6k on it and again no oil top up required. However, i was told that it was normal with VW to need top ups and to simply swing by the service dept and they would take care of it at no cost. I am no mechanic but 1 lt every 3k soulnds like there is a problem.
    V6Passat
    Here now!
    My brothers Golf GTi has had to have the oil filled up, with warning light, on 4-5 different times since I bought it for him. The car is around 1.5 years old now.
    I have told VW about it and they always tell me its normal for GTi to use this much oil?? Its not leaking cause ground is clear wherever the car is kept.
    My EOS and Passat have same engine and they have never had the oil warning light come on though..
    Feb 2010
    MILPERRA NSW
    yes i know its amazing i have called numerous people over this problem and they all say its normal so now i have taken it in and told them that i want to have a oil level check every 1000km so see how this goes who knows if they will tell you the truth then even they are in the back I cant see what they are doing they could top it up with heaps of oil and tell me it was fine and only needed a small amount who do you trust will keep yous posted on outcome ,Debbie
    Jan 2007
    brisbane QLD
    are you able to speak to another service centre about this?
    I mean, as a competitor to your normal service centre, they should be keen to point out what they're doing (as you mentioned you don't know what they're doing in the back of the shop)
    You should be able to get some honest tips, if they want to earn your business
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
    We did what Debbie is wanting to do already. They topped it up then told him to use it for 1000km and bring it back for a check. They said it went down a bit but seemed normal
    Canberra
    Debbie,
    You should check the oil level before you take it in for checking by your dealer, and afterwards, that way you will have a pretty good idea of how much your engine used and what they added while "in the back".
    IMO VW's claim that using up to 1 litre per 1,000Km is "normal" is just so they can deny there is a problem when there is one. I wonder if a car that is burning that much oil would pass a strict emission test.
    I've never had a car that wasn't severely worn use even 250 ml per 1,000Km. My last car (Laser TX3 DOHC) didn't use much oil at all, even after 190,000Km, and neither of my current vehicles use much either (I never have to add any between oil changes).
    Feb 2010
    MILPERRA NSW
    Yes thanks ill check it on the dipstick before i take it in ,also I have called other VW specialists and mechanics and they all say the same thing they seem to cover each other Debbie
    Canberra
    The other thing to remember is just because a lot of VWs use excessive amounts of oil doesn't mean that they are 100% OK mechanically.
    In other words all these engines that use excessive amounts of oil probably all have the same fault: rings that aren't scraping the oil off the cylinders properly so too much oil is getting into the combustion chamber and being burnt.
    So when they tell you "That is normal, they all do that" you can reply "No, not ALL of them do it, only some, and it is NOT acceptable".
