Results 1 to 5 of 5
Thread: VW Touareg - rough start- 2017 V6 Tdi
    Jul 2011
    Perth
    Hi There,
    I have noticed an issue with my 2017 TDI V6 Touareg at start-up, which has a very rough idle and started to shake.
    I have only started noticing this at a cold start. I scanned the car without any indications or clues from the sensor readings. Could someone point me in the right direction regarding what I should look at?
    Please advise.
    Scan below
    Friday,10,November,2023,05:17:34:41771
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
    VCDS Version 23.3.1.0
    Data version: 20230421 DS346.2
    Ross-Tech: Home
    Mileage: 182587km-113454mi Repair Order: 000
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 69
    6C 6D 72
    Mileage: 182587km-113454miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    These engines suffer quite badly with carbon buildup (due to the EGR system) in the intake pipes and intake manifold which is well known to cause hesitation and stuttering when the engine is cold and/or light throttle.
    Id say there is a fair chance that this is the issue you are experiencing.
    Its the same case with the V6 TDI in my Audi SQ5 which shares some similarities with engine design to your car. My car has 95,000km and ive cleaned it 3x times as well as fitting a catch can which has helped slow the issue down.
    You can remove the parts yourself and clean with carby cleaner but its a messy job, otherwise you can have the service done by a mechanic but obviously you will pay handsomely for it.
    Jul 2011
    Perth
    Thanks mate I'll give this a go. Looks very hard to take off plastic components.
    Quote Originally Posted by ak77 View Post
    Some of the bolts are a bit tricky to get to and you will need some extensions to get at some of the others, but its definitely DIY'able if you have the right tools and are willing to give it a go.
    I tried all sorts of cleaning products, from petrol, to dedicated EGR cleaners and found this Nulon carby cleaner to be the best to dissolve the muck. Also buy yourself a couple of medium/stiff bristled toothbrushes to use to agitate the cleaner. Nulon Pro Strength Throttle Body & Carby Cleaner 400g | Supercheap Auto
    Also, just so you know - this product does basically nothing so don't waste your time/money/effort trying this. Liqui-Moly Diesel Engine Intake Decarb - 326g | Supercheap Auto
