Rotors, Pad and Sensors all four corners......
Hi Transporter,
Where would you recommend I get the rotors and all the gear from in Adelaide? I am just up the hill from you.....
thanks, Gus. 2009 V6TDI, also marvellous......
![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Transporter
Front brakes replaced now, the rear ones still have 3mm+ remaining indicators aren't on yet.
Here is the picture of the front brake disc. Despite it looks not that bad they have to be replaced, since there is only 1mm on each side of the disc allowed for wear, so the discs would be 2mm undersized (the scrap limit or min thickness is 32mm). I used RDA slotted discs with Remsa front pads, the back brakes will get also slotted discs but with the Bendix 4WD brake pads.
And the new discs fitted.
![](http://www.vwwatercooled.com.au/forums/images/imported/2013/12/R0041541JPG-1.jpg)
2009 V6 TDI....Marvellous....
