Results 1 to 7 of 7
Thread: V6 tdi
    Nov 2008
    Perth,WA
    V6 tdi
    I'm in the market for a pre-owned Touareg and am aware that the motor initially had 500nm of torque. Can anyone advise me when the motor was upgraded to 550nm? Obviously I would prefer a motor with the upgrade and would like to be able to distinguish which is which.
    Thanks in advance for your advice
    May 2010
    Charters Towers, QLD
    Quote Originally Posted by octagon View Post
    I think out of memory it was early '09
    dont worry about the OEM upgrade of power... Just get it re-flashed and get 600nm!
    Adelaide hills, SA
    From week 46 approx.(November) in 2007 - on.
    Jan 2008
    Kurrajong Heights, NSW
    From week 46 approx.(November) in 2009 - on.
    Our V6TDI delivered in May 2008 has the more powerful motor. Build date early 2008.
    T Rex
    2008 T2 V6 TDI Atacama/Anthracite, Air Susp, Bi Xenons, Sunroof, Fogs, Roof Rails, Tow pack, full size spare inside car
    Adelaide hills, SA
    Quote Originally Posted by T Rex View Post
    Sorry, that should be November 2007. We missed on the stronger more economical motor by two weeks
    Thanks T Rex for picking it up. Time flies, it's unbelievable.
    Jan 2008
    If you intend to tow or go seriously off road then I would suggest you keep your eye out for one with air suspension. The self levelling characteristic is great for towing heavy trailers - also keeps the lights level. Fully up the air suspension gives up to 300mm clearance. Cheers. Geoff
    T Rex
