Results 1 to 8 of 8
Thread: Treg2 brake controller
    Aug 2007
    Ballarat Victoria Australia
    Can anyone assist me with info re the fitting of a brake controller to the current Touareg. Dealer knows nothing. want to use a hayman reese, any tech articles welcome.
    Adelaide hills, SA
    Quote Originally Posted by armdlo View Post
    Did you get the factory towbar?
    Aug 2007
    Geelong,Victoria,Australia
    Smile
    Hi Armblo,
    I had the Haymen Reese/Tekonsha brake controller fitted to my T2 a couple of months ago.
    Of course you will have to also install the the distribution controller box as well to get everything working but I must say its a nice installation.
    Braking on my 2 ton caravan has not felt so good, just take the time to ensure you set it up correctly.
    I your interested Umhauers Towbar Centre in Geelong fit mine, Ph:5229 3910.
    Regards,
    Treg2
    Aug 2007
    Quote Originally Posted by Treg2 View Post
    Hi Armblo,
    Regards,
    Treg2
    Hi Treg2
    Thanks for the fitter in Geelong but what is a "distribution controller". Is that something to do with LED lights on your caravan
    Aug 2007
    armdlo,
    Hope the info was a help.
    If you had a factory tow bar fitted it would have had the controller box fitted in the area of the disc changer. If you purchased a third party bar such as a Haymen Reese you would have been told that you require the genuine controller box supplied as well.
    The controller box interfaces with the ECU and allows the trailer light to operate correctly, it also has some smarts which detects the trailer connection and informs you of any failed bulbs as well as changing the auto transmission gear changes.
    As for the subject of LED's, that's a whole other bucket or worms.
    Treg2
    Aug 2007
    For the case of LEDS You need to fit resistor to the trailer cable, as the leds draw less current then the bulb monitor thinks you have a blown bulb. I fitted one to a Cayenne not too long ago. I will check my notes mate, im sure you need a Micro relay as well , ill get back soon on that. I have a diagram somewhere im sure. i fitted a Porsche bar and a Brake controller to that and he had a trailer with LEDS.
    Stay tuned
    Alba European
    Aug 2007
    LEDs
    Thanks Jimmymac
    I await your reply, the caravan maker( where the LEDs are) has some bulky plug-in device that incorporates a whole new 7pin socket mounted on a board!!, your fix seems preferable.
    Aug 2007
    factory towbar
    Quote Originally Posted by MRL T5 View Post
    YES, sorry I havn't got back on this, I didnt understand that VW might have fitted a module of some
