Originally Posted by
Sunshineviking
How did the vehicle get on on Stockton Beach? I'm planning a trip to Fraser Island in the near future. any Tips(tyre pressures - I note that the manual does not reccomend lowering on sand)
cheers
I started with what I thought was low tyre pressures at 20 psi (137 kpa) and was having some problems entering the soft sand tracks onto the beach. This may also have been due to taking it a little too easy and not using the vehicles full power, but I then lowered to about 15 psi (100kpa) and it was fine all day. Heaps of dunes to run up and down on and some soft very dry tracks.
Make sure you turn off ESP to allow some give in going up the dunes, turn it back on when coming down the other way, the HDA (hill descent assistance) works a treat for this.
I had sand for a while after the beach but found the best way was a high pressure hose after a good dry out and just blow it away.
Flipper Dog
Now - T-Roc R, Audi Q5
