Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 48
Thread: Touareg R5 and Biodiesel
  1. #31
    Sep 2008
    I meant "of all golf diesels", only the 125kW has DPF. There is a thread I have seen somewhere, perhaps on a biodiesel forum where all cars with DPF were being collected.
    2015 Polo Comfortline 6M + Driving Comfort Package
    2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
    (2008 MY09 Polo 9N3 TDI retired hurt hail damage)
  2. #32
    Sep 2006
    Greg,
    In Touaregs at least, the R5 engine was the last to get the DPF, as it was the "oldest" TDI used and started life without one. The V10 had DPF from at least 2005, and the V6 had it from first introduction. I think thet R5's didn't get them in Touaregs until the 2007 model (sold from later 2006). My 2005 R5 TDI Touareg doesn't have one.
    Bluey, I think your info was true at one time but is now out of date. All current VW passenger TDIs in Australia (polo, golf, jetta, passat, tiguan, touareg) have DPF.
    The issue with DPF and biodiesel is really quite simple:
    1. DPF is put there to comply with EURO emmissions rules, and is certified as such.
    2. Certification testing was done with current euro-standard petroleum-based diesel, not biodiesel.
    Therefore:
    3. VW cannot guarantee that their car complies with the euro emmissions standard with biodiesel and therefore to ensure compliance, must put the no-biodiesel sticker on the fuel door.
    None of this has anything to do with the engine as such, just with the post-treatment of the exhaust gasses. All diesel engines will run without ill-effect on good quality diesel whether it is derived from petroleum, canola oil, waste cooking oil, sunflower oil, tallow, or the waste from liposuction clinics
    ..Neil
    Audi Q5 2.0 TDI
    sold and missed: '05 Touareg R5TDI
    SWMBO: '08 Golf Pacific TDI DSG
  3. #33
    Canberra
    Quote Originally Posted by Moonan View Post
    All diesel engines will run without ill-effect on good quality diesel whether it is derived from ........, or the waste from liposuction clinics
    So if I go for the surgical weight loss option I should tell the doc to keep the (human) fat and I'll be able to run my van for oh, 15 - 20 km or so ? LMAO
  4. #34
    Sep 2008
    Where is that documented?? Certainly new TDI models will have DPF to meet new Euro IV regs. VW brochures current today say:
    No DPF in:
    * Polo TDI MY08 or MY09.
    * Golf V TDI 1.9 and 2.0(103kW)
    * New Beetle (current spec dates March 0.
    * Jetta MY08 TDI (still current).
    DPF is in:
    * Golf V TDI 2.0(125kW)
    * Passat MY09
    * Tiguan TDI MY09
    * EOS TDI MY09
    * Touareg TDI MY09
    BTW, I understand the main problem with biofuels and DPF has to do with the potential level of carbon collected resulting in either DPF clogging or the unburned fuel which is periodically sent to the DPF via engine to regenerate the DPF causing DPF temperature problems. Other than that, there are numerous reports of injector clogging and premature failure and expensive repairs from lower grades of biofuels without additives. High grade biodiesel with additives seems to cause less problems.
  5. #35
    Adelaide hills, SA
    Quote Originally Posted by bluey View Post
    No DPF in:
    DPF is in:
    * Passat MY09
    * Tiguan TDI MY09
    * EOS TDI MY09
    * Touareg TDI MY09
    Why would you want fewer problems and want to use biodiesel?
    I'm sure you meant no problems, so get over the biodiesel issue and use fuel you were recommended.
    Biodiesel = less power
    higher fuel consumption
    needs more servicing (more oil is wasted, fuel filter last 1/2 life)
    cost the same as normal diesel
    risk to your engine - not tested for long enough in PD TDi (under all conditions)
    Why some people want to use biodiesel? It really beats me.
    P.S. note that VW brouchure had date on it and also it referes to cars already in production, so it could be a year behind, so it could be your owners manual.
  6. #36
    Sep 2008
    I didn't know about biodiesel until Top Gear made their own. The green alternative and processing used vegetable oil rather than dumping in landfill is superficially attractive.
    This site has a fairly thorough treatment of the general issues involved apart from DPF.
    http://journeytoforever.org/biodiesel_FIEM.html
  7. #37
    Adelaide hills, SA
    But if you cars life is shorter than it would otherwise be when running on normal diesel that it goes against environment and much more pollution is created by making another car to replaced the one which didn't last and that’s not talking about harmful emissions generated by that car which is running not well because of the biodiesel made it sick and the driver doesn't know it yet. When you start losing power and you take it to mechanic it could be several hundred Km's since. Repair bill goes to $thousands. Think twice if it is worth it.
    Car manufacturers are protecting their product by saying no to biodiesel I'm giving them credit for that. Drivers who experiment with their diesel engine by trying biodiesel, they should check negative affects first to see what could be a conferences from that and than make their decision. That is not always a case.
    Diesel fuel made today from crude oil has to be used by someone (has to be sold).
    Why should one take a risk and use biodiesel when petroleum diesel should be used.
    Don’t wrongly assume that biodiesel with higher cetane number will give you more power. The opposite is the truth.
    You gaining nothing by using biodiesel.
  8. #38
    Apr 2008
    Quote Originally Posted by MRL T5 View Post
    Do you work for caltex or BP ?
    I disagree with your opinion. Biodiesel is widely used in other countries. In Newcastle, Caltex diesel has ~5% biod from Rutherfords. Why would they do that ? Perhaps it has benefits ? Currently dino diesel is the exclusive domain of big oil companies. Bio can be produced by small or medium companies or even home users with the right local resources. I grasp the biod doesnt give the equiv power or range, but it has alternate properties that you ignore. Simply saying that its a huge risk doesnt cut it with me.
    My golf doesnt have a dpf and I had no problems with bio at 100% or mixed at 10%. A workmate toured Europe in a rented polo over 2 months using biod when available with no problems.
    In the end its a personal decision by the owner, but feel free to contradict me
    MY08 2.0L TDI DSG
  9. #39
    Adelaide hills, SA
    Quote Originally Posted by greygolf8 View Post
    No I don't work for any oil company.
    I'm diesel mechanic by trade with over 28 years experience.
    I'm not going to argue with you, if you are happy to use biodiesel because your workmate used it for 2 months with no problems.
    To me it is just a little bit short time for testing.
    If Oil Company blends biodiesel to petroleum diesel the quality is controlled, risk is minimum and diesel is made to DIN EN 590.
    Biodiesel is not DIN EN 590 and warranty is voided and if you use only biodiesel right from the day one you could be for very expensive repair bill just before the warranty runs out.
    Good luck.
    P.S. Today's CR diesel engines can run on nano particles of AL, Fe and many other metals with minimum modifications and good results. Idea from 80's but metal filings stuffed up the engine very early.
    Anybody for experimenting with different kind of fuel?
  10. #40
    Sep 2006
    Bluey, I apologise, I made the mistake of believing a salesman... the 1.9 and 103kW 2.0 in Golfs are indeed shown in the current VW Oz website as not having DPF's. And I think it is a current brochure (ie up to date) as it refers to "Pacific" and "edition" not comfortline etc...
    MRL T5, I know you are very "anti" biodiesel, and that your position is very common amongst diesel mechanics who have seen or heard of lots of different snake oil made and sold as alternative fuels over many years. But please be careful to state your opinions showing respect to others who might either have a different view, or indeed have done some different research and found some different answers .
    I respect your right to your opinions, and what follows is not to try and convince you - but to provide an alternative point of view for readers of this thread - one which is based on my research and experience...
    For example, the owners manual for my R5 Touareg is very clear in approving biodiesel, the only stipulation being that it must meet the relevant standard. Indeed they are equally clear in stating the penalty for using substandard biodiesel - the fuel filter will need to be changed more often.
    Also, the biodiesel factory at Rutherford was developed and is owned and run, I believe, in association with a large family trucking business. They do not make this stuff to con unwary motorists, they make it to fuel their fleet of trucks that travel millions of km every year. IMHO, they wouldn't do this if it cost them money or damaged or shortened the life of their engines. Every batch of biodiesel made there is independently certified to meet the Australian Biodiesel standard (ComLaw F2006C00556), and exceeds the requirements of the euro-std. The feed stock for this plant is varied. It was mostly canola oil before the drought, and is currently around 95% recycled cooking oil.
    As such, I have been happy to run my Touareg R5 on mostly B100 for around 100,000 of the 120,000km on the clock so far. This is only my personal preference, others are free to differ.
    cheers,
    ..Neil
    Audi Q5 2.0 TDI
