Hi dmm_au,
I dont know where VW messures the ground cleareance, I only messured mine and I found the cleareance to be 195-200mm. That is at its lowest point on the rail next to the front wheel. The plastic bash plates lowest point is 200-205mm. I am driving at the moment a new courtesy V6 TDI with air suspension, on normal, the lowest point again is 195-200mm, on heigh, it is 245-250mm, on extra, heigh it is 280mm.
After my steel suspension lift and larger tyres (265/65/17) mein is at 245-250mm depending on air or load.
Markus
