Sorry I did not see this thread earlier.. have been busy.
http://i11.tinypic.com/6cn1e2g.jpg
http://i5.tinypic.com/2lcwbrb.jpg
This is in rural NT with standard tyres, you will not be disappointed imho.
I'm planning on getting the Cooper ATRs. They don't come in 255/60R17, but they do come in 235/65R17 104T (739mm) which is almost exactly the same diameter, and therefore will show on you speedo as 0.1% too slow. VW and Mercedes both 'support' this size.
I'm attracted by the guarantee of 50K as I read stories about rapid tyre wear on the Touareg. The catch is you need to let a Coopers examine them every 10K, not sure if there would be expense involved (ie tyre alignment)
David
'08 T2 TDV6 Atacama Grey Metallic Anthracite Leather Lacquer Inserts T/Bar Chrome Roof Bars Fifth Wheel, Pirelli 235/65/17 ATs, 550nm of Torque
Just been reading up on the Coopers - some horror stories out there - but I think some of these guys are doing serious offroad stuff with them.
I'll be doing a bit more research before I buy - I'll post the results on here
cheerio
2007 R5 TDI Lux Salt Lake Grey, Wheel Carrier & park sensors.
1967 Bettle deluxe bored out to 1600cc.
if you want more general 4wd info and on tyres etc this is a handy forum, get some more treg owners on there.
http://www.4wdmonthly.com.au/forum/
B6 Passat Wagon No KESSY
re warranty with a chip:
the ecu can record fuel and other pressures when a fault is thrown and it is easy to tell if a chip has been fitted to the car, even if its removed before going to the workshop. just thought id mention that![]()
2x Caddy, 1x Ducato
I've got Cooper ATRs on my Treg, and other than a bit more road noise that the OEM Olympics, they've been very good and long wearing. I've got nearly 30k on them and there still seems to be plenty of meat to the wear indicator. I do have a spare wheel to share the wear and I also rotate them every 10k.
They were on the car on run I did to Cameron Corner and the performed very well. I've also done a little harder stuff in the Brindabella Mountains. I'm pretty happy with them.
Other Treggers run Pirellis and BFGs and seem to be happy with their choice.
Bob
2009 LR D3 SE
2005 Touareg R5 Lux - gone
Thanks Bob - looks like they'll be ok fro what i'll be doing then.
The car has Goodyears on it now. I have about 15k left on my rears and 5-10 on my fronts so I'll get them rotated and a 4 wheel alignment done this weekend. I won't be heading off the beaten track until the weather dries out a bit up here so I'll be ok for now - Might head up to Fraser Island for the Aussie day weekend to try the sand and hopefully not need to use my new maxtrax.
All the best
viking
just a Q... why dont you treg blokes pick up a cheap set of indestructible steelies and fit your offroad tyres to them and keep the road tyres on the nice alloys? then dimensions wouldnt matter so much would they?
2x Caddy, 1x Ducato
