If you have VCDS you can enable development mode, then you can hold down the setup button on the RNS (keep holding it) until you get the 'secret menu' which will give you version information.
Hi Guys,
I have scanned the RNS-510 with VagCom, and it scans a lot of detail but leaves the firmware version blank (just dotted lines......) I wanted to know what firmware I had so I could go through a careful upgrade path and not brick the thing. Any ideas?
Gus
2009 V6 TDI....Marvellous....
Thanks, not sure how to enable development mode, I'll read the VCDS manual. The secret menu can appear on some firmware versions by holding setup, but not on mine. I purchased VCDS and the adaptor to sort this and some other weird indications of faults I get intermittently.
Thanks for the info, I'll take a look.............
Gus
Thanks Kamold,
Works. Changed 0 to 1 and did the soft reboot and can now see the menu. Have 0802 in the RNS, now just will check on various forums if an upgrade will give me any additional features.....
Thanks again,
Gus
Earliest firmware version I've heard of is 0900.
What is the part number?
The DAB option is there but greyed out, as is BT Audio - that's why I was lookt at FW upgrades to see if I could get these features usable.
