Results 1 to 10 of 13
Thread: RNS-510 Question
    Jun 2009
    Aberfoyle Park SA
    RNS-510 Question
    Hi Guys,
    I have scanned the RNS-510 with VagCom, and it scans a lot of detail but leaves the firmware version blank (just dotted lines......) I wanted to know what firmware I had so I could go through a careful upgrade path and not brick the thing. Any ideas?
    Gus
    2009 V6 TDI....Marvellous....
    If you have VCDS you can enable development mode, then you can hold down the setup button on the RNS (keep holding it) until you get the 'secret menu' which will give you version information.
    Jun 2009
    Aberfoyle Park SA
    Rns-510
    Thanks, not sure how to enable development mode, I'll read the VCDS manual. The secret menu can appear on some firmware versions by holding setup, but not on mine. I purchased VCDS and the adaptor to sort this and some other weird indications of faults I get intermittently.
    Thanks for the info, I'll take a look.............
    Gus
    Quote Originally Posted by biggus View Post
    Gus
    Sorry I should have clarified - you want to enable development test mode on the RNS USING VCDS.
    Open address 47 navigation, then go to coding and turn on test mode, then reboot the RNS for it to take effect.
    Jun 2009
    Aberfoyle Park SA
    Rns-510 - vcds
    Brilliant - thanks Kamold. I'll try it on the weekend.
    Jun 2009
    Aberfoyle Park SA
    Thanks Kamold,
    Works. Changed 0 to 1 and did the soft reboot and can now see the menu. Have 0802 in the RNS, now just will check on various forums if an upgrade will give me any additional features.....
    Thanks again,
    Gus
    Earliest firmware version I've heard of is 0900.
    What is the part number?
    Jun 2009
    Aberfoyle Park SA
    RNS
    Part No is 7L6 035 680B
    HW version H02
    Jun 2009
    Aberfoyle Park SA
    The DAB option is there but greyed out, as is BT Audio - that's why I was lookt at FW upgrades to see if I could get these features usable.
    Dab and bluetooth require seperate hardware, they cannot be enabled with a firmware update.
