Hi Guys, i believe this should be a solution, I had was given a solution for my R36 (also on this forum under passat)
The part Number is VGA0055204 LOAD LED LOAD SIMULATOR 5A-300708RA
This is setup for a flat 7 pin design so assume there is a version for round also.
The pack consists of a Male/Female extension with the load simulator in the middle, an instruction leaflet and a set of cable ties. The idea is this thing gets strapped (or permanently mounted) to the trailer, plugs into you towbar lead before connecting to the trailer plug.
I believe these are about $200, however I do not know the exact price as it came with the towbar kit as a peace offering for the stuff ups I had along the way (a long story)
I was told it was a deliberate piece of reverse engineering to fix the problem that is large issue with Touareg owners. I believe Bosch have also come up with a solution that can be a mod to the vehicle wiring but this is an expensive fix.
Gone...........R36 Icelandic Gray Wagon
Specialising in off-topic discussion
