Results 1 to 10 of 17
Thread: A new twist to trailer light issues. help needed
    Jan 2008
    Cooroy, qld
    I have a 2008 TDI which is still going like a dream. Dealer tow bar fitted on purchase
    Picked up a new trailer this week with LED lights. No surprise the lights played up. Interesting the car lights are fine and so are the brake lights on the trailer. So running / side lights dont work on the trailer. (car is fine at the same time). Same story with the indicators. They are working on the car but not on the trailer.
    Returned home and got the ball mounted bike rack out. It has all incandescent lamps. No LEDs. Same story. Lights on the car are working. Indicators and running lights not.
    Check all the fuses and can not find a fault there.
    Is there a remote trailer control unit with a fuse I am missing or something else.
    May 2014
    central, Vic
    Do you know if the car is fitted with a VW trailer loom with its own brain or a generic relay box ?
    What format trailer plug, flat, round, 5 7 12 pin ?
    Jan 2008
    Cooroy, qld
    No Jeff, not sure what loom was used. It was installed at purchase. Trailer plug is large round 7
    Jan 2008
    Cooroy, qld
    Booked into the autoelec. so we will soon see
    Adelaide hills, SA
    Quote Originally Posted by harks11 View Post
    Make sure that they're familiar with the late model VW electrics, otherwise they could do more bad than good, despite they're autoelectricians.
    Jan 2008
    Cooroy, qld
    Well all fixed with the add of a load box if I run LEDs. It seems that the trailer adapter was programmed for the US and they reprogrammed it the faults went away. Given the car is six years old I am somewhat puzzled that that could be the case. Wondering if some sort of spike scrambled it.
    However, time will tell. The Auto Electrician has one of the best reputations in Brisbane specialising in Euro cars. They charge to match.
    Jul 2016
    Australia's Bush Capital
    Nope, that's dealer nonsense.
    The intermediate LED 'black box' is the trick for LEDs; or an electric braking setup for towing - I have both.
    I don't know why VW sales people don't ask this question when you order a vehicle.
    Cheers,
    Stu
    MY07 V10 TDi Touareg
    98,000 Km
    HPF flash tune - 273 rwkW & 813 Nm
    Dec 2008
    Sydney/Canberra
    If only the brake lights are working, regardless of what lights are on the trailer, it means the trailer control module hasn't been coded to the car at all. Even once it's coded, you'll need the load box for LEDs.
    Nonetheless, you've got it sorted which is great.
    Jul 2016
    Quote Originally Posted by Umai Naa!! View Post
    That doesn't make sense, and is not true. What trailer control module? The LED connector? Nothing needs to be "coded", if the wiring is done correctly.
    I acknowledge your 3,900+ posts, but this issue is an easy fix and should not be persisting.
    Cheers,
    Stu
    98,000 Km
    Dec 2008
    Sydney/Canberra
    Is it a genuine VW wiring kit?
