Do you know if the car is fitted with a VW trailer loom with its own brain or a generic relay box ?
What format trailer plug, flat, round, 5 7 12 pin ?
I have a 2008 TDI which is still going like a dream. Dealer tow bar fitted on purchase
Picked up a new trailer this week with LED lights. No surprise the lights played up. Interesting the car lights are fine and so are the brake lights on the trailer. So running / side lights dont work on the trailer. (car is fine at the same time). Same story with the indicators. They are working on the car but not on the trailer.
Returned home and got the ball mounted bike rack out. It has all incandescent lamps. No LEDs. Same story. Lights on the car are working. Indicators and running lights not.
Check all the fuses and can not find a fault there.
Is there a remote trailer control unit with a fuse I am missing or something else.
No Jeff, not sure what loom was used. It was installed at purchase. Trailer plug is large round 7
Booked into the autoelec. so we will soon see
Well all fixed with the add of a load box if I run LEDs. It seems that the trailer adapter was programmed for the US and they reprogrammed it the faults went away. Given the car is six years old I am somewhat puzzled that that could be the case. Wondering if some sort of spike scrambled it.
However, time will tell. The Auto Electrician has one of the best reputations in Brisbane specialising in Euro cars. They charge to match.
MY07 V10 TDi Touareg
98,000 Km
HPF flash tune - 273 rwkW & 813 Nm
If only the brake lights are working, regardless of what lights are on the trailer, it means the trailer control module hasn't been coded to the car at all. Even once it's coded, you'll need the load box for LEDs.
Nonetheless, you've got it sorted which is great.
98,000 Km
Is it a genuine VW wiring kit?
