It is possible to swap out the red MFD with a colour one, however finding one would be the problem. Removal of the instrument cluster is required and some coding changes.
RNS-510 will fit with an updated canbus connector.
Diesel is your friend with Touaregs, the petrol ones like to support multinational oil companies.
You will find the 5 cylinder more than capable to tow as with the patrol ones.
The early model Touaregs only had air suspension for the V8 and V10 TDI models. If you stretch out to the 2006 - 2007 model years you can pick up a V6 TDI with air suspension.
Bang for buck would be a stock R5 TDI for towing duties, a canbus adaptor and RNS-510 fitted. The standard steel suspension works well for towing and comfort.
If you can find a loaded V10 TDI than would be a nice buy but could end up costing you some serious dollars in repairs over time.
I would suggest look out for a facelift (T2) V6 TDI 2007 model with air suspension for the extra coin.
Flipper Dog
Now - T-Roc R, Audi Q5
