Results 1 to 10 of 16
Thread: Hmm... $1179AUD to replace the brake pads
    Bexley, NSW
    Hi guys,
    My first post here. Seems like this is a great community.
    Well, the brake warning lamp of the Treg is on and my dealer checked the brakes, disc are fine but pads need to be changed. They quoted me the following:
    $550 for the front pads
    $360 for the rear pads
    + 2 hours of labour
    = $1179 for the whole job.
    It seems to be very expensive. They kindly explained that the brakes are attached to the sensors and new sensors are required. If I take it to someone else, make sure I use genuine pads with sensors etc. Does it normally cost that much to replace the pads only?
    This is the first time I change brake pads for the Treg (done 32000KM) and any advice would be appreciated.
    Oh, I live in Sydney and quoted from Artarmon. Don't mind traveling if I can get it done somewhere else cheaper ... sorry for the long post :-P
    Feb 2008
    Richmond, VIC
    Defo call around and get a couple of quotes. both dealers and independents.
    Brake pads shouldnt affect your warranty if they arent done by a dealer, same as tyres etc.
    currrently... MY10 GTI | DSG | Candy White | Sunroof | 18's | BT | MDI
    previously... MY08 GT TDI | DSG | Reflex Silver | Sunroof
    U can get aftermarket pads that come with the wear sensors
    84 MK1 GTI
    01 DC2R
    Bexley, NSW
    Thanks guys
    Anyone know where to get it done independently in Sydney? I guess dealers will be quoting similarly, but I will certainly try.
    Camden, Sydney
    That seems outrageous.
    We do heaps of brakes on VWs and Audis and its never close to that much.
    I use German branded OEM pads with the wear sensors and we ause VW trained staff and factory software.
    Its an easy drive to us at Campbelltown and I can quote you and book you in if you call me with the VIN, and vehicle details so I can confirm the pad type and price.
    Aug 2007
    Five Dock, Sydney
    PM me your VIN and I'll give you the necessary part nos to check...
    Also, check out ECStuning.com for comparitive pricing whilst the AUD is 90+c
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Bexley, NSW
    Ah, thanks guys. I will get the VIN later this morning and contact you again
    Apr 2010
    Parramatta NSW
    Re: Hmm... $1179AUD to replace the brake pads
    I just changed all four rotors and pads to suit on my gti, all up including labour was $980. And it stop just as well if not a bit better then oem.
    Golf Mk 5 GTi - 3 door
    Stock Standard
    Forge Spacer,Nav,HID,Brembo Rotors and Pads
    138.8Kw at the wheels
    Bexley, NSW
    yeah Ramesh, that's why I think $1179 pad only is out of ordinary.
    Jun 2007
    Sydney, Australia
    Quote Originally Posted by inzane View Post
    + 2 hours of labour
    And you weren't quoted for discs? Add another $500 each end to that.
    Point to remember that a 2.5 ton Touareg with 330mm Brembro brakes is not a Golf at half that weight.
    Flipper Dog
    Now - T-Roc R, Audi Q5
