your flashing too many hot babes![]()
What's the go? The main beam bulbs keeps blowing at random times. I've chanaged the bulbs probably 4 times in the past year and it can happen on either side (not at the same time, though).
Any ideas?
Thanks
2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
Without Your Seatbelt, You Know Your Gonna' Die!
Project: mk1 cabriolet 20vt
Are you running the H7 bulbs?
Are they 55W or 65W rated?
All i can think of is that you may have overpowered lights that keep burning themselves out.
2006 (MY05) Touareg V6 Luxury. Sorry, should've included that.
Check the Voltage on the globe terminals. With engine running at idle the voltage should be 13.2V max. Have an assistant to open throttle to increase engine RPM briefly over 2500 again the voltage should be 13.2V I know that very often I measured higher voltage but the globe manufacturers don't accept the warranty if the globe is showing formation of the ball at the posts. Also make sure that the globe is properly seated in the headlight.
This may seem like a silly question but are you touching the glass on the bulbs at all? If so the oils in your fingers will create hot spots and lead to premature failure.
