Results 1 to 10 of 14
Thread: Headlights keep blowing
    Albion QLD
    What's the go? The main beam bulbs keeps blowing at random times. I've chanaged the bulbs probably 4 times in the past year and it can happen on either side (not at the same time, though).
    Any ideas?
    Thanks
    2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
    Feb 2010
    your flashing too many hot babes
    Without Your Seatbelt, You Know Your Gonna' Die!
    Project: mk1 cabriolet 20vt
    Albion QLD
    Quote Originally Posted by DUB84 View Post
    Hahaha niiiice. No need to flash em, once they see the sunroof, they're automatically in
    Jun 2009
    Are you running the H7 bulbs?
    Are they 55W or 65W rated?
    All i can think of is that you may have overpowered lights that keep burning themselves out.
    Albion QLD
    Quote Originally Posted by team_v View Post
    Pretty sure they're H7 bulbs, the ones that came stock.
    I cbf getting a new one last time so I used the main bulb from my old headlights, it was H7 but I think it's the other side that's blown now.
    Adelaide hills, SA
    Quote Originally Posted by maca View Post
    Any ideas?
    Thanks
    What model and year is your car?
    Albion QLD
    2006 (MY05) Touareg V6 Luxury. Sorry, should've included that.
    Adelaide hills, SA
    Check the Voltage on the globe terminals. With engine running at idle the voltage should be 13.2V max. Have an assistant to open throttle to increase engine RPM briefly over 2500 again the voltage should be 13.2V I know that very often I measured higher voltage but the globe manufacturers don't accept the warranty if the globe is showing formation of the ball at the posts. Also make sure that the globe is properly seated in the headlight.
    Albion QLD
    Thanks, I'll give that a go (if I can get into the terminals without removing the lights).
    The only way to get to the bulbs/terminals is to remove the entire cluster. But appreciate the picture anyways
    Jan 2010
    North Shore
    This may seem like a silly question but are you touching the glass on the bulbs at all? If so the oils in your fingers will create hot spots and lead to premature failure.
