Results 1 to 10 of 13
Thread: EGR Cooler REplacement
    Jan 2008
    Kurrajong Heights, NSW
    About 600kms ago my Touareg wanted a coolant top-up. Took almost 3 litres. 600km later it needed another 2 litres. No sign of external leaks but internet search revealed it could be the EGR cooler leaking into the exhaust system. Took to dealer today and suspicions confirmed - unfortunately engine out job. 6 months out of warranty but hopefully VW will come to the party. Anyone else had similar experience? Geoff
    T Rex
    2008 T2 V6 TDI Atacama/Anthracite, Air Susp, Bi Xenons, Sunroof, Fogs, Roof Rails, Tow pack, full size spare inside car
    Dec 2005
    Rockhampton Qld AU
    I almost bought a V6Tdi but it had low coolant and check engine alarm. So far I'm happy with my R5.
    '11 Polo TDi auto, White, Sunroof
    '91 Transporter syncro camper
    Jan 2008
    Hi njg02. Glad you are happy with your R5. I am overwhelmingly happy with my Treg and the service from my dealer has been fine. It is undoubtedly the best proper (dual range) 4WD I have owned over the last 30 years. I am hoping VW has the integrity to do the right thing with this fault which obviously should not have occured. Cheers. Geoff
    T Rex
    maybe research into an EGR delete for the Touareg? You'll never have a problem again!
    Jan 2008
    Quote Originally Posted by GoLfMan View Post
    Now that IS lateral thinking! Mind you there is a very long list of complicated technology I would love to delete from modern cars.
    T Rex
    Apr 2009
    Wow engine out ???. I have changed several of these and didnt take the engine out...... They were all V6TDI
    Jan 2008
    Quote Originally Posted by Ratstylz View Post
    Hi. That's what I thought looking at the workshop manual and indeed VW has confirmed that it is not an engine out job. Thank goodness.
    T Rex
    Apr 2009
    Hi, Check this out, might help with the cost..
    Technical product information Transaction No.: 2018615/9
    Engine: Coolant warning light on, no leak on outside, exhaust recirculation cooler leaks Release date: 18-Aug-2010
    Customer statement / workshop findings
    Vehicle consumes coolant. No coolant loss to the outside.
    Technical background
    The coolant loss can be caused by a leaking exhaust gas recirculation cooler. As a result, the leaking coolant is burnt.
    Production change
    Optimised cooler for exhaust gas recirculation from manufacturing date: 02.07.2008
    A: manufacturing date
    Engine number from:
    CARA: no change Phaeton
    CEXA: 002053 (04.07.200 Phaeton
    CASA: 040744 (04.07.200 Touareg
    Chassis numbers from :
    Touareg: WVGZZZ7LZ9D
    Measure
    Free or remove the EGR cooler. Coolant marks within of the EGR module can be seen either with the naked eye or with an endoscope. In most cases, there are also incrustations on the exhaust gas temperature sensor.
    If this is so, replace the EGR cooler.
    Check the complete exhaust recirculation system for coking and clean the affected areas.
    Warranty accounting instructions
    Service number/damage code/manufacturer: 2643 / 0050
    Accounting with APOS
    Repair operation number
    Designation
    Time units (TU)
    Phaeton 3D*
    Main operation
    26 43 19 35
    Remove and install EGR cooler
    570
    Associated operation
    26 43 01 99
    Check EGR cooler
    20
    26 43 29 99
    Clean EGR system
    The repair operations include all the work of this TPI.
    Designation
    Time units (TU)
    Touareg 7L*
    MKB: BUN
    Main operation
    26 43 19 34
    420
    26 43 01 99
    Check EGR cooler
    20
    26 43 29 99
    Clean EGR system
    Designation
    Time units (TU)
    Touareg 7L*
    MKB: CAS*
    Main operation
    26 43 19 37
    680
    26 43 01 99
    Check EGR cooler
    20
    26 43 29 99
    Clean EGR system
    Accounting with APOS/2:
    Model
    Illustration
    Position
    Number
    Designation
    Activity
    Time units
    3D*
    131-55
    1
    131511
    19
    3D*
    131-55
    1
    131511
    Check EGR cooler
    02
    20
    3D*
    131-55
    1
    131511
    Clean EGR system
    30
    Touareg 7L*
    MKB: BUN
    Model
    Illustration
    Position
    Number
    Designation
    Activity
    Time units
    7L*
    131-60
    1
    131512
    19
    7L*
    131-60
    1
    131512
    Check EGR cooler
    02
    20
    7L*
    131-60
    1
    131512
    Clean EGR system
    30
    Touareg 7L*
    MKB: CAS*
    Model
    Illustration
    Position
    Number
    Designation
    Activity
    Time units
    7L*
    131-65
    1
    131511
    19
    7L*
    131-65
    1
    131511
    Check EGR cooler
    02
    20
    7L*
    131-65
    1
    131511
    Clean EGR system
    30
    The labour times are correct at the time of publication. The time units (TU) may differ slightly, if the repair catalogue has been updated. The information in the repair operations catalogue applies, except for the open time items (... 99).
    The necessary time for using the diagnostic tester are not included in the above times; they are kept separate.
    Use the above times only for this TPI.
    Jan 2008
    Thanks for that. If anyone has a good email address for warranty support at VW Australia I would appreciate it. Sent an email to the only address I could find on their website (volkswagenassist@) on Thursday morning - not even an acknowledgement yet.
    T Rex
    Jan 2008
    Update. The problem has been fixed. EGR cooler replaced by dealer. VW paid for part and 50% of labour as goodwill so at least that is a positive story about VW. My contribution approx $500 including various seals that also needed to be replaced. Can't complain. Better to fail now and be fixed rather than halfway across the Simpson Desert!
    T Rex
