Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: To Air or not to Air?
    Jan 2008
    Kurrajong Heights, NSW
    Question To Air or not to Air?
    Hi, I am a new member seriously contemplating a Touareg V6 TDI (test drive next Thursday). Previously have owned 2 Range Rovers, an X5 and currently a 2005 Prado. We need to tow a heavy trailer (race car) and we also want to be able to do outback camping trips as we did in the RRs. Why the Touareg? - hopefully it will combine the fantastic qualities of the X5 with the offroad ability of the others.
    My initial thought was to go the conventional steel spring suspension (simple, nothing to go wrong etc) but there are some serious arguements for the air springs given my intended use (keep car level when towing + extra clearance for off road).
    I would opt for the air setup in a flash if I knew it was reilable (unlike land rover) - can any members share their experiences with Touareg air suspension with me? Thank you
    Melbourne, Victoria
    I hope you're impressed with your test drive.
    I suspect you're going to find, air is an option that only the V10 owners have.
    I considered it, but it is an expensive option, that frankly I figured had great potential to make me unhappy. Also I couldn't find a vehicle with air to test drive, which meant I couldn't disprove the Topgear review, where they said the air suspension created a seasick inducing motion.
    I reckon you should ask you question on clubtouareg.com
    There are more US drivers with air suspension.
    David
    '08 T2 TDV6 Atacama Grey Metallic Anthracite Leather Lacquer Inserts T/Bar Chrome Roof Bars Fifth Wheel, Pirelli 235/65/17 ATs, 550nm of Torque
    Jan 2008
    Thanks David - I have now posted the same message with clubtouareg. My test drive will be in a steel sprung model. Today I have checked with Polyair and they would be willing to make/install a set of polyair springs for about $600. I have these on the Pardo and keep things level with a trailer hooked up or a heavy load on board. Could be a smarter (and much cheaper option than air).
    Geoff
    Air suspension
    Hi TRex
    All of the current model Euro 4wds that have air suspension feel like crap ....IF set to the 'comfort' setting !
    Set to Auto or sport .........most are fine. I have GL320 cdi Mercedes and on 'comfort' it would not be wise to travel down a undulating/bumpy/poorly maintained pothole road - as per all others you feel like the vehicle is over compensating for the bumps it feels by 'floating' the body over the suspension. This is the same for the Cayenne, Q7 and V10 Treg. These same vehicles feel fine in 'auto' of 'sport'........having said that.......do not pay for air on a V6. Only if you are after the V10 (becuase it has it standard) would I get it in a Treg. The standard sprung car is absolutely fine for your intended use. Also if you get the chance have a look at all the plumbing and wiring in an air suspended car...........geezus.........wouldnt want them out of warranty !
    Jan 2008
    Thanks for the responses so far. Can someone with steel springs confirm for me if the rear springs have the shock external to them or do they have the shock/strut running through the centre. The latter would preclude fitting Polyairs, the former would open up that option.
    Geoff
    Jan 2008
    Today I have learned vis clubtouareg that the rear springs have the shock up through the centre so Polyairs are out. Before I decide on airsuspension am I worring about nothing? Given the experince in this forum I guess I should ask you folks with steel springs if the back of your Treg drops noticeably with a heavy load and/or when towing a decent sized trailer - do you find your lights hitting the tree tops rather than the road? Thanks
    Geoff
    Jan 2007
    South Australia
    Welcome to VWwA T Rex
    Most of the Aussie 4x4 mags have been happy with the steel suspension as the ride is better out in the sticks.......but if you need ground clearance go the air suspension although its around 8.4K last time I looked up the VW pricelist
    Good Luck with your purchase
    - Ben
    1961 Karmann Ghia Coupé - 1993 Golf Cabriolet - 2006 Golf Comfortline 1.9L TDI
    2008 Jetta 2.0L FSI
    Mar 2007
    Canberra
    T Rex (great handle btw, was a bit of a fan in my youth)
    I have the steel springs and regularly tow a 1.3t camper trailer, and while the there is a sag of about 10mm, it doesn't affect handling. VW rates the towbar at 350kg ball weight, which is a fair bit.
    I'm not sure that the polyairs (or something similar) couldn't be done. There was an R5 owner from Wollongong who had air bags fitted to his rear suspension and a compressor and tank installed in the luggage compartment. He had someone in Dapto fit the system, and it was pretty exy as I recall. I haven't heard from him in a couple of years.
    The Treg also has height adjustable headlights. There's a thumb switch that raises and lowers the headlight angle, so you shouldn't have any trouble.
    I'm looking at getting new springs and shocks to give me a little more lift. Bilstein make shocks for the Treg, and I believe Lovell will do some springs. Another R5 user in Sydney has this combo and is very happy. I suspect it won't be a cheap fit.
    Bob
    2009 LR D3 SE
    2005 Touareg R5 Lux - gone
    Jan 2008
    Thanks everyone for your ideas and sharing your Touareg experience with me. Combining these with comments from the clubtouareg.com forum have allowed me to make a decision to go with the air suspension.
    There is no doubt that the simplicity of coils is great but given that I cannot fit air bags to the coil-over rear springs and I don't want to change springs and shocks then air suspension is the way to go given my towing/heavy load requirements.
    Any problems folks have with the air suspension seem to have been minor rather than outright failures and on earlier cars rather than later ones so we will give it a shot. (and really test VW roadside service beyond the black stump if it fails).
    I test drove a T2 V6 TDI with air suspension last Thursday and was very impressed. My preference would be to use the "sport" suspension setting on sealed roads as I don't like a soft set up, although on corrugations the "auto" setting seemed better. Given that the $8400 Air Suspension option also includes the $3000 Xenon package it is not too bad. As I live out of town good lights will be handy. The V6 TDI is awesome.
    So... this week I will order a 2008 Reflex Silver (Anthracite interior) V6 TDI with Air Suspension/Xenon, Sunroof, Towing setup, fog lamps, roof rails and a spare wheel (no tyre) to carry on longer trips.
    Next decision - what's the best tyres to suit mainly selaed roads but some serious off roading from time to time - I'm thinking Pirelli Scorpions but I guess I had better check other threads in this forum! Comments?
    Thanks guys.
    Geoff
    Towing Touareg
    Hi TRex
    Just a quick one with your intended purchase;
    this is for IF you intend towing over 2000kgs only (and since you are intending on towing a race car may well be the case) - you may already know an electronic brake controller must be installed in your vehicle (ADRs). Try finding a competent installer in your area who has done this before (ie installed the controlller utilising the VW brake control module which monitors trailer light (globe) failure.........GOOD LUCK with finding one !, and get a figure for installing it to throw into the 'bargaining' equation. Of the five auto electricians I called (including those recommended by their local VW dealer) only one 'suggested' they had done one before, two said they had tried but couldnt work it out, one had attempted -spent two days - gave up and gave it back to the dealer and another said they wire it independently because they cant 'interface' an aftermarket electronic brake controller with the VW brake electronics !
    Good luck !
