Results 1 to 5 of 5
Thread: 21 inch Mallory wheels
    Hi Guys,
    Can someone advise the stud pattern and offset for these wheels which come standard on the V8 TDI?
    I am looking to change to to Black Gloss rims and need info to shop around.
    Have tried search function but couldnt see info.
    Cheers All.
    David
    Golf R MY 11.5 United Gray, 3 door, DSG, ACC, Free MDI, Bluetooth
    Mods - APR Downpipe, VW Racing AI, HPFP, APR Tune Stage 2+- lovin it!
    Touareg V8 TDI R-Line, White .Arrived 11 July.
    Should be 21 x 9.5, ET59, PCD 5 x 130 - but that's not official. As you suggest, information on these isn't everywhere.
    If you have the vehicle already (judging by your sig) just check the wheel for the width and offset information, normally stamped on the back/inside?
    +1 as Dutch said worst case take one wheel off and the info should be stamped on the inside (unless you can get a hand/camera around the back and snap a shot at the right place).
    Cheers all.
    Jul 2016
    Australia's Bush Capital
    Given a wheel size and vehicle model, measure from the centre of one stud to an adjacent stud.
    It's 85mm for a 19" Touareg, for example.
    That will tell the wheel guy if its 5 x 120 or 5 x 130.
    Dishing and offset follows from the model.
    Cheers,
    Stu
    MY07 V10 TDi Touareg
    98,000 Km
    HPF flash tune - 273 rwkW & 813 Nm
