Results 1 to 10 of 14
Thread: 09 factory Towbar Noise
    Jun 2009
    Aberfoyle Park SA
    To all those who use their Touareg as a tow vehicle ( and what a tow vehicle it is!)
    The towbar hitch receiver moves up and down (rocks) around the lock pin (uses the lock pin as a pivot) - so every time you go over a bump in the road, brake or accelerate you hear a "clunk" - very annoying (only rocks 1 or 2mm or so at the towball) If you look at a Hayman Reece hitch, there is the pin plus a lock bolt underneath that tightens after you insert the towball to the receiver making this rocking movement impossible. This solution is silent no matter what the road conditions. Anyone been able to get over this with the factory bar? Doesn't matter whether it's a small trailer or the boat.
    Any advice would be appriciated.
    Adelaide hills, SA
    Welcome to the forum biggus.
    Don't forget to use forum's search function, if nobody answers your question.
    Also try in here.
    http://www.clubtouareg.com/forums/f67/
    Mar 2007
    Canberra
    Hi biggus
    I thought I had the OEM hitch because it was fitted by the dealer and it had the locking bolt. You could easily fit one yourself by drilling and tapping the hole to suit.
    2009 LR D3 SE
    2005 Touareg R5 Lux - gone
    Dec 2008
    MANSFIELD VIC
    The Best Bars hitch that the dealer fitted to my Jetta does the same thing. I'm yet to do it, but I'll soon be putting a small bit of foam around it to stop the play (and clunking). Fitting my own locking bolt may be another option.
    HAVE: '12 SUPERB ELEGANCE SEDAN 103kW 4x4 TDI DSG | LAVA BLUE | SUNROOF | KESSY | 3x BLINDS | PARK ASSIST | PADDLES | TINTS | NOKYA YELLOW FOGS | TOWPACK
    HAD: '09 MKV JETTA TDI DSG | SALSA RED | XENONS | TOWPACK
    Jun 2007
    Quote Originally Posted by Jase View Post
    That sounds the same as the towbar fitted to my Jetta and I had the same problem when I got mine. There is a locking bolt underneath the towbar, from memory you need an allen key to nip it up and keep the towbar toungue tight.
    Clunking noise gone!
    George
    06 Jetta 2.0TFSI Killed by a Lexus!
    09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
    14 EOS 2.0 TSI has arrived!
    Jun 2009
    Aberfoyle Park SA
    Tow Bar Noise
    Thanks for the advice guys, I'll have a good look for that allen bolt and hope it's that simple - otherwise shims.
    Thanks again.
    Jun 2009
    Aberfoyle Park SA
    Towbar Noise
    Just an update: No bolt or Allen Key. Oh well.....shims. Seems a crazy way to have to fix the problem, but so be it.
    Thanks to all.
    Sep 2006
    I had the same bar as bob - dealer fitted... These were made by either Hayman Reece or Best Bars (NZ) and had a small threaded hole drilled in the bottom or one corner of the square tube for a small bolt to be tightened against the tongue. As you have observed Biggus it seems the factory bars fitted to more recent Tregs don't have this. It would be easy to get done if you can get to any sort of workshop and would be easier for multiple use than shims.
    cheers,
    ..Neil
    ..Neil
    Audi Q5 2.0 TDI
    sold and missed: '05 Touareg R5TDI
    SWMBO: '08 Golf Pacific TDI DSG
    Aug 2008
    Tanawha Qld
    Wink
    Hi guys, may have info to help with noisy tow bar. Just had a genuine bar fitted by dealer and the 'tongue' (hitch) is from Best Bars in NZ and yes with the standard hitch pin it rocks and clunks just like the Reece and others do. Supplied with the kit was a locking pin made by Valley Industries in Ca. USA which must be the latest from VW in response to the issue. The lock part of it is a bit of a joke, but the thing completely stops the movement. It's not as simple to remove and install the hitch if you don't want to leave it on full time but it's so much better than that clunking racket.
    Of course there's another solution if you can wait. Drive the beach a few times, don't wash off the salt, go thrugh some mud and dust and in 6 months or so there will be so much rust n stuff in there it won't rattle either. Not the best solution I guess.
    Schootsie
    08 R50 Biscay Blue, RNS510, Electric tailgate, tow bar
    Adelaide hills, SA
    Quote Originally Posted by schoots View Post
    Schootsie
    Hi mate,
    could you please post the picture of it, so others know how it look like? I have tow bar but never tow, so I don't know if mine is noisy or not.
