I notice that some new car models are being promoted as having "Timing Belts that will last for the life of the car". Be nice if that meant a Lifetime Warranty, wouldn't it? Earlier generation belts would stretch with age, new generation belts fail by breaking or losing teeth.
Replacement recommendations for VAG vehicles seem to have moved down to 4 years or 60,000 miles/ 100,000 km or sooner, with annual belt inspections. Apparently there is much less wear with extended open-road driving and shorter trips with few stops and starts, than occurs if you have a daily stop and start commute on congested motorways and crowded city roads, which can halve the life of your timing belt (and other parts prone to wear).
We can all buy some peace of mind by unclipping the Upper Timing Belt Inspection Cover every 6 or 12 months, and rotating the crankshaft pulley with a socket on the central bolt. Examine your timing belt for damage (delamination, fraying or cracking when twisting the belt by 90 degrees). Not so easy to examine the belt tensioner, unfortunately, which might need complete dismantling of all belts and pulleys. The Serpentine external drive belt and accessories belts should also be checked for damage.
A seized bearing in the belt tensioner is not uncommon, due to lubrication drying out or overheating, and the nylon teeth can crack or disintegrate. Most engines are "interference clearance" now, so that valves will strike piston heads if the valve cam stops turning due to timing belt damage, and the damage can be disastrous. Versions of my Audi A4 1.8 litre engine with 5 valves per cylinder were also an option in some Audi A3 and A6 cars, VW Passats, and Skodas. Service information that I have suggests that the Longitudinal-mounted 1.8 engine had the water pump driven by an external accessory belt, but the Transverse engine mounted crosswise (A3) had the water pump driven by the Timing Belt, and the increased load and wear results in a shorter timing belt life (and disaster if the water pump seizes). Apparently the design of the timing belt and tensioners on the 1.8 5-valve engines similar to my Audi ADR version were changed in 1998, because of premature belt failures. You might find this document from Gates Corporation (Europe) of interest.
See http://partsforallcars.com/spares/pdf/gates010.pdf for full bulletin. Apparently Gates and VAG decided to redesign the Timing Belt drive on these Passat and A4 1.8 engines because of failures. The wax-filled actuator on the belt tensioner has been replaced with an oil-filled actuator, the belt with 152 teeth has been replaced by a different stock belt with 153 teeth, and the new tensioner has a spacer washer 3mm thicker than the old design, and a different idler. The upgrade replacement kit contains more parts, so you can expect a higher price (well, it is for Audi and Volkswagen, isn't it?). Any of the experts out there care to share their thoughts and experience on this topic? The rest of us will continue to drive and hope for the best! John.
