Thanks for the post brackie.
I'm new to VW forums, and to diesels as well.
I've posted around the place about run in's and championed the motomanusa concept. Certainly have had several great results from this in the past.
Thing is, thankfully, I've had the unique nature of the TDI's and the specific lube they require highlighted to me. This kind of goes against what a typical, mineral oil based, run in is all about. I'm sure that following the high combustion pressure concept highlighted in both the initial post, and in motomanusa is the best way to force rings against the cylinders and achieve a good seal, but just wondered about peoples views of doing this with synthetic oil, which kind of minimizes the effect.
I understand specific oil is required to be low ash - for the particle filter, and high shear ( synthetic ) for the cam followers in the diesel head.
Are there no oil options with the diesel??
