Great work pete, i do seem to remember the discs being larger diameter tho, for some reason i thought 278, would be worth testing with one from the wreckers.
Unfortunately i cant help a lot anymore, my rally car is off to its new home in QLD. If it does help, i didn't know what size caliper spacer i needed when starting, it was a matter of sit the caliper on the disc, pack it with washers until it fit well, critical thing is to make sure it dose not rub too much and that the disc runs true.
The stopping power is far far greater than mk1 GTi (mk1 gti setup on the rear of my rally car was not good enough for gravel! i used camira front calipers with mk1 gti vented discs on the rear, i would go quite a bit larger for tarmac racing)
76' Mk1 Rally Car, 1800 8v haltech ecu
94' Fairmont Ghia, v8, big cam, leather, perfect for towing golfs
89' EA ex taxi, lpg, cheap and easy
