Results 1 to 10 of 14
Thread: Could this be a sign of thing's to come!!!
    This engine & invention is truely remarkable & could change the face of motoring & all sort's of industry's if picked up!
    Imagine the performance industry! Throw one in the back of a beetle! haha
    The basic 14" engine capacity is 850ci & makes 850hp! 814ft/lb at 850rpm!!!!!
    It makes more power at idle, than most current super car's at full throttle!
    http://www.angellabsllc.com/index.html
    Equiv. To 32 Cylinder, 4-stroke-cycle Diesel
    Bore--mm(in) 76.2(3)
    Stroke--mm(in) 95.25(3.75)
    Displacement-- Cu in(L) 848 (13.**
    Aspiration Normally
    Compression Ratio 25:1
    Rotation (from Fly Wheel end) CCW/CW
    Cooling System Oil Cooling
    Lub Oil System--Quart drysump, 5
    Weight, Net Dry (Approx.) Kg(lb) including flywheel . 68 (150)
    Advertised hp (KW) 850(634) NA 3,000 (2,23 SC/TC.
    http://www.youtube.com/watch?v=kGlUZg2pC0Q
    http://www.youtube.com/watch?v=Itl9ipaIJ_o&NR=1
    http://www.youtube.com/watch?v=_MBYg...eature=related
    http://www.youtube.com/watch?v=vfjAq...eature=related
    It also has the potential to run at 150miles a gallon!
    The prototype version is also running on diesel/bio diesel
    That 814ft/lbs was with 150psi of air pressure too. No combustion!
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Very interesting stuff! If it takes off I'll be very impressed. This is the sort of engine that's probably work best in a deisel-electric vehicle where the motor can run at it's optimal revs.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    Feb 2007
    Simply Awsome!
    MK1 GLS 3door
    A4 B7 2.0T
    Canberra
    Sorry, but put me down as a skeptic: "If it seems too good to be true, then it probably is ! "
    Feb 2007
    Quote Originally Posted by gregozedobe View Post
    They got it to work and they spent over 4million dollars on it. It would be one expensive gimic both in time and financialy.
    MK1 GLS 3door
    A4 B7 2.0T
    May 2009
    Western Sydney, NSW
    Blog Entries
    1
    Yeah, I've been thinking about it and something doesn't quite fit. I think the 2 biggest questions I have are:
    1) How is this engine going to deliver all this power to a gearbox? With making the engine smallet, you have to make the crank shaft smaller too don't you? Whatever the crank is made of is going to have to be able to handle the torque output by the engine, otherwise it's just going to shear and remndering the engine design useless.
    2) Like the rotary engine, this looks like it'll be a fairly thirsty beast. I can't see how it's going to be more efficient than a standard 4-stroke engine. We'll see though.
    Apr 2008
    If it's so good, why hasn't it made more press or been mass-produced yet etc etc. It's been around a while.
    2000 Mk IV GTI
    i looked it up, they ran out of developement funds.
    Its now going into production I believe
    Dec 2008
    Perth
    Quote Originally Posted by GoLfMan View Post
    Looks like a whole load of hype, but no feasible product. I have yet to see one with any fuel in it
    MY14.5 VW Polo 81tsi Comfortline - Candy White - Comfort Pack
    May 2009
    Cooling it is going to be a huge issue - if you have that "32 cylinders" combusting in that small space - how are they going to get rid of all the heat?
    Pete
    MY13 Octavia vRS TDI DSG
