Originally Posted by
gregozedobe
3 Use an impact driver - this gives a straight on go at the screw and adds in a jerking force too (both good).
Preen59
Not such a good idea on smaller screws. I avoid using an impact driver on anything less than about 16mm bolts if they're pretty tight.
The problem is that the impact can damage the head. I've done it before in a vac form tool, and buggered it. I had to peen the top over, bash a T bar into it and get it out that way..
If they're too tight you're better off using a method that you have feel with.
How did using an impact driver cause damage to the head ?
If the bit fits properly it can only slip if the metal of the screw or bolt head is inadequate to transmit the torque required to undo the bolt, and that is not due to the use of an impact driver.
We might have to agree to disagree
I have had lots of success with an impact driver on stubborn screws down to 5mm stem diameter, and particularly when the screws are made of crap metal. The jerking rotation of the impact driver seems to break the "freezing" of the thread (common on steel screws into aluminium thread), whereas if I simply gradually increased the torque I just twisted the heads off (did I mention crappy 1970's spanish "steel" screws on Montesa trials bikes ?).
Once I got them undone I replaced them all with better quality high tensile allen head screws, no further problems (with getting screws undone, anyway).
